Go Back   Truck Forum > Truck Classifieds
Reply Truck Classifieds - List your truck, parts & other items for sale.
Old 08-17-2009, 02:26 PM   #1
Wyley87's Avatar
Wyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to behold
two sided door lock cylinders
ok im looking for a set door locks that use the the same two sided key that my ignition switch uses. i have checked at auto zone, orielly's, the chevy dealer, and all over the internet looking for them to no avail. Anyone got an idea other than a junk yard where i can get these?
96-GMC C1500 305ci 2WD
K&N FIPK Cold Air Intake
Rebuilt Motor (should have gone 350) and Trans
05 Nissan Xterra 4.0 V6
No mods so far
Cost money to go fast...How fast do you wanna go?
Wyley87 is offline   Reply With Quote
Old 08-17-2009, 02:29 PM   #2
i think LMC truck and JCWhitney sells them. might be the only place other than a local yard to get them. if this is for the 96, good luck with one fitting the ignition too. being that chevy uses wafer cylinders, it is possible to take the lock to a reputable locksmith and have them changed out so it will work both.
Old 08-17-2009, 03:06 PM   #3
Wyley87's Avatar
well i can have them re keyed at the chevy house for $10 a lock. the only ones i have been able to find have been the single sided. but i didn't look at jcwhitney so ima have to check them out.
No mods so far
Old 08-17-2009, 03:28 PM   #4
Wyley87's Avatar
well i looked on JCwhitney nothing
No mods so far
Old 08-17-2009, 03:37 PM   #5
single sided, double sided, it really doesnt matter. a double bit key will work in a single cause thats all it reads. a double bit key only enables you to put in in either way without looking at it. might be why you can find a double sided. only thing that matters to you is making sure you have the correct keyway.
Old 08-17-2009, 03:41 PM   #6
Wyley87's Avatar
well actually i think my key is the same on each side. so that would make sense i just have to check
No mods so far
Old 08-17-2009, 03:44 PM   #7
it is the same on both sides. early 90 models had singles that would only go in the keyway one way. yours doesnt matter though and thats why you dont see single cut keys anymore.
the ignition reads every cut on the key but not the door. the door only reads 3 cuts on that key which makes it possible to have a valet key, when it comes to the glovebox. i believe there are 9 or 10 cuts on a 96 chevy key.
Old 08-17-2009, 03:55 PM   #8
Wyley87's Avatar
so basically the ones at autozone are the right ones just i was just being a dummy lol
No mods so far
Old 08-17-2009, 06:27 PM   #9
basically, if the key fits, buy it. there are several different brands of locks out there but that doesnt mean that each key fits only one lock. i.e., kwikset, titan, and wiesner, are all different lock makers but you can use one key on all different locks just because they use the same keyway.
and you are not a dummy. just being cautious because you were unaware. big differance between arrogant and dumb.
Old 08-17-2009, 09:51 PM   #10
Wyley87's Avatar
well it just didn't make sense to me why i couldn't get a set od two sided locks at a dealer but i just didn't know lol kinda like the rv cam
No mods so far
2003 GMC Sierra ‘sleepy’ door lock JohnnyB60 GMC Truck Forum 11 08-03-2009 02:01 AM
Pass. Door won't lock automatically. Mikes96Z71 Chevy Truck Forum 5 01-21-2009 03:11 PM
Manual door lock question goatman Chevy Truck Forum 1 06-11-2008 11:17 AM
Where Is The Door Lock Code Lukka Ford Truck Forum 4 05-15-2007 06:45 PM
93 PU door lock Billy Toyota Truck Forum 0 11-29-2006 05:14 PM
