02 chevy cold start rough idle
Discussion in 'Chevy Truck Forum' started by drozzus, Feb 21, 2012.
  1. drozzus
    drozzus New Member
    Feb 20, 2012
    i have a 2002 chevy silverado 4wd 5.3 v8 with 143,000 miles on cold start the rpms ramp up to 200 for about 30 secs and drop to around 500 and barely stays running. after warms up runs fine, a local mechanic changed 02 sensors all 4, plugs, wire, cleaned injectors and throttle body. i changed tps sensor and ran fuel injector cleaner thru tank. i have codes of too lean bank 1 and 2 random cylinder misfire, and idle air excessive. any help would be appreciated
    12,658
    7,766
    what is the reading on the scanner for the ecm temp sensor?
  3. drozzus
    drozzus New Member
    Feb 20, 2012
    I don't know will have to check
    22,406
    13,171
    Your getting to much un metered air in ..check for vacuum leaks at throttle body..air filter system...to throttle body
    Make sure it is all sealed tight...pcv valve... check all hoses...check the idle air control valve.
    Also clean the maf sensor.
  5. drozzus
    drozzus New Member
    Feb 20, 2012
    Ok will check it out
