02 Dodge Dakota Trans. stuck in park
Discussion in 'Dodge Truck Forum' started by rockyard37, Jan 3, 2010.
  1. rockyard37
    rockyard37 New Member
    Jan 3, 2010
    My 02 Dakota Quad cab sport's transmission is stuck in park. It acts like it is frozen. |The temp outside is 13 deg. It worked fine yesterday, and it was that cold.
  2. bradrhale
    look under and verify that you have operation of the shift linkage. it may have frozen up and not allowing for it to work. did you set you e brake over night?? it may be frozen against the drum.
  3. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    The parking brake wouldn't have any effect on the shift linkage.
    Where and how is it parked? (Street/driveway/parking lot? Level ground/uphill/downhill?)
    Being parked on a hill can put a lot of force on the parking pawl in the tranny, making it difficult to shift out of park. I've also seen some trannies get jammed in park from just a gentle bump (someone parking behind, etc.)
    What I do, and what I taught my g/f to do is... While your foot is still on the brake, and before shifting to park, use the other foot to set the parking brake, then shift into park and take your foot off. What that does is take a lot of the strain off the tranny and the linkage (putting it on the brakes, where it belongs). Starting up and going somewhere is the reverse, foot on the brake, shift to drive, release the parking brake and go.
  4. bradrhale
    i guess what i was thinking is that the vehicle was stuck in park meaning could not move. not that the tranny could not be shifted. perhaps i should get the coffee before answering the questions.
  5. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    do you have to apply brake before shifting on that dodge.
  6. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Could be a defective brake lock mechanism too and I would think more likley. Might even be something as simple as a brake light. One of the work trucks, using cruise control, It would not kill the cruise after you tapped the brake pedal. Ended up being a rear brake light bulb out. If its not brake applied safety system, then BB's suggestion of being torque locked may be it too. Funny BB, I taught my wife and dauther the same exact thing. Do not put it in Park until the E brake is applied, then shut it off and put it on gear.
  7. rockyard37
    Jan 3, 2010
    I guess the linkage must have been frozen. I let the truck run for a half hour and now it works fine.
  8. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
    good deal. cheap repair!!:bow::bow:
  9. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Great news. Thanks for the comeback and letting us know what it was.
  10. BernieB
    BernieB Full Member
    Jul 11, 2009
    3,880
    37
    One of the nice benefits of doing this is that if the vehicle gets hit while it's parked the shock doesn't get transmitted through the drivetrain. I've seen trannies and mounts get damaged pretty bad even in minor accidents, and you don't always know about the damage until after you already have the check from the insurance company.
