03 chevy truck runs 2 seconds and then dies
Discussion in 'Chevy Truck Forum' started by slim, Jan 5, 2008.
  1. slim
    slim New Member
    Jan 5, 2008
    I have a 2003 chevy silverado 4.3L. It died driving down the road. Now it will start and run for 2 seconds then it dies. I have tried to scan it for codes. But it will not make a connection. I have reset the passlock. and reflashed the comp. The scanner still has no connection.
  2. Hayden
    Hayden Senior Member
    May 21, 2006
    387
    12
    Bay City,Michigan
    Put a fuel pressure gauge on it and see what the reading is when you turn your key to on.(don't start it).
  3. slim
    slim New Member
    Jan 5, 2008
    #3 slim, Jan 6, 2008
    fuel pressure
    It has 58 lbs. of pressure. it does not lose fuel pressure when it dies
  4. stumpuller454
    Dec 26, 2007
    2,206
    65
    that is way to much fuel pressure! this can cause just as much a problem as not enough pressure! its probly flooding your truck! may need to purchase a new pump! they have an internal regulator, but check for power at the pump, may be getting too much somehow, also check your ground,
  5. mudseeker
    581
    not sure but i think the newer trucks require that much pressure. i think there is a cam sensor or something that deals with the fuel pump once the engine is started. maybe the oil pressure sensor.
  6. Hayden
    May 21, 2006
    387
    12
    Bay City,Michigan
    Yeah I agree with Mud, 58psi is about normal, I can't think of anything that'd shut down that quick to kill your engine. Can you start it right back up after it dies?
  7. slim
    slim New Member
    Jan 5, 2008
    Yes it starts everytime.
  8. mudseeker
    581
    mr 75 could probably tell you but he seems to be on vacation, lucky:D
    anyways, i'm pretty sure it has something to do with your oil pressure sensor. i think if the newer trucks do not sense oil pressure it cuts power to the pump in an atempt to save the engine.
    might want to give the dealership a ring and try to confirm this idea.
  9. red_atv
    red_atv Member
    Jan 8, 2008
    i dont know if 03 has a built in security system on it ,but on the 98 if the fuse is either pulled or blown it'll run for a few seconds then die.starts right back up runs for 2-3 secs. and dies again.
  10. scottie
    scottie Senior Member
    Jan 6, 2006
    644
    Mercedes Benz tech
    South Florida (Palm Beach), originally from south
    i bet it is the crank sensor. the engine turns over and starts running, and the PCM waits 2 seconds to receive the input from the crank sensor. if it doesnt receive the signal, it shuts the fuel pump off after 2 seconds.
    mudseeker likes this.
