1.6 Roller Rockers good for any power?
Discussion in 'Chevy Truck Forum' started by 94Z71350, Feb 16, 2010.
  1. 94Z71350
    94Z71350 Senior Member
    Feb 16, 2010
    74
    Military, USAF
    Moore, Oklahoma
    Over the stock non-roller 1.5 ratio ones? Looking for a couple more ponies, truck is a 94 Z71 TBI 350 with a CAI & True dual flowmaster exhaust, also plan on adding a chip from TBIChips.com soon too. :confused:
    I was looking at these https://shop.enginekits.com/osb/itemdetails.cfm?ID=3087 and was wondering if they would work or not.
  2. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,279
    112
    Moore, OK
    I am thinking these may be more inteded for the Vortec 350 SFI motor with an aftermarket cam 94Z. And probably a pretty big cam too being they are long slot, or possibly just to get the 1.6 ratio too. Of course its just going to give the valve a hair more lift is all its going to do. Maybe one our fearless leaders, Mudseeker, who is more fluent in SBC SFI will have more accurate info to add.
  3. gmctrucks
    8,584
    4,184
    I know one just can't put them on without doing other head work.
  4. davbell22602
    winchester, va
    welcome to the forum
  5. bubbatrucklover
    bubbatrucklover Senior Member
    Jul 29, 2009
    952
    Jacksonville, Florida
    Such as? Just askin' not being a Smart A$$.:D
  6. 94Z71350
    Feb 16, 2010
    74
    Military, USAF
    Moore, Oklahoma
    What about 1.5 roller rockers, self-adjusting. I would think they would be a direct bolt on, no?
  7. mudseeker
    581
    roller rockers on a flat tappet cam? you'll be lucky to see 1 hp gain. rockers would be the last thing on the list for upgrades. there are other items that will give you a better hp to $ ratio, such as a cam.
    as hotrod said, you'll get a hair more lift with the 1.6, but you can get more lift for just a little more $ with a cam. i bet i could find you a good cam for another $75, but that would require an almost complete engine tear down.
  8. hotrodpc
    Jul 29, 2008
    7,279
    112
    Moore, OK
    Exactly what I was thinkin, but figured Mud would be the more experienced in this area.
  9. gmctrucks
    8,584
    4,184
    I have heard that one has to do work on the heads or the holes where the push rods go. Like I said I have heard that on another forum. I'm going to see if I can find the post.
  10. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    when changing rockers to larger size you need to be wary of valve geometry.especially with roller rockers. as far as making pushrod holes bigger, you would then have to install guide plates. unless you are running a lot of rpms you really dont need larger pushrod holes. larger holes let your oil return faster to oil pan so you dont pump it dry at higher rpms.:eek:
