1975 F250 starting problems
Discussion in 'Ford Truck Forum' started by chrokeva, Aug 25, 2012.
  1. chrokeva
    chrokeva Member
    Aug 25, 2012
    Have a 75 F250 w/360 tried to start it and it would turn over but die, rebuilt the carb with same results. everytime the starter is engaged the engine will fire, when the key is let go it dies. Im figuring electrical possibly the coil or maybe the ignition module, it has electronic ignition with the module. theres not much to the motor being a 75. I know if the items are broke replacement will be required, but how to tell which one.
    22,214
    12,851
    Sounds like the ignition .switch to me . See if there is power at ignition fuse when you let the key off.
  3. chrokeva
    chrokeva Member
    Aug 25, 2012
    would that be the switch itself on the dash or the module
    22,214
    12,851
    The switch on the dash turn it to on see if there is power on both side of the ignition fuse .
    Welcome to the site .
  5. chrokeva
    chrokeva Member
    Aug 25, 2012
    I havent had a chance to check the fuses but I know that if I turn the key on all the dash lights come on, does that mean there is power going through the switch?
    22,214
    12,851
    So your saying as long as starter is engaged turning the engine it runs? Try this check for power at the coil when key is on.
    Prime the engine see if it runs good for a few seconds when key is let off.
    22,214
    12,851
  8. elgemcdlf
    elgemcdlf Senior Member
    Nov 5, 2011
    95
    Sounds like it might be a bad ballast resister. When cranking the resistor is bypassed providing 12V to the coil. When in run the resistor drops the voltage to something like 9.8V. I would run a wire from the + of the battery to the + of the coil & try to start. If it starts & stays running you are on the right track. To kill the engine you will need to disconnect this jumper wire. Do not run it this way as it will burn out your coil but you can do it for testing purposes.
  9. chrokeva
    chrokeva Member
    Aug 25, 2012
    bought a new module and installed it, would not even fire even when starter engaged. put on the old one and when starter engaged fired until I released the key. bad module maybe, something else maybe. am going to use the jumper from the batt to the coil tomorrow, what size wire would be to small?
  10. chrokeva
    chrokeva Member
    Aug 25, 2012
    will run when starter engaged but dies when key is let go, if you prime it it just revs higher then dies.
