1979 F150 - good brakes soft pedal?
Discussion in 'Ford Truck Forum' started by picnik, Apr 18, 2011.
  1. picnik
    picnik New Member
    Apr 17, 2011
    Winter job> deicer @ milwaukee wiscosin general mi
    Grafton, Wiscosin
    #1 picnik, Apr 18, 2011
    i've got a little problem. i've got a 1979 ford F150 with the inline 6. i put all new lines and new rear wheel cylinder along with a new power booster and master cylinder. my problem is that i've bleed the master cylinder and the lines mulitple times now and the pedal still is soft, there's brakes n they stop good but the pedal is still soft. it there any way to tighten up the pedal so it's not so soft n drop 1/2 down to the floor? any help would be great because i've run out of ideas!!
  2. Case 7230
    Have you adjusted the rear brakes up?
    12,305
    7,407
    sounds like air, if you hold the pedal down hard does it continue to weep down?
  4. picnik
    picnik New Member
    Apr 17, 2011
    Grafton, Wiscosin
    thanks case ill have to try that an seen!
    leolkfrm no it feels like their mannual brakes they compares down then get rock hard to stop the truck n some times they'll lock up if pressed to hard!
  5. Lonesome7.3
    Lonesome7.3 Full Member
    Jul 21, 2008
    5,061
    987
    Columbus GA
    Are you sure the new power booster is working?
  6. picnik
    picnik New Member
    Apr 17, 2011
    Grafton, Wiscosin
    i adjusted the rears n they helped alot so i think thats the problem
  7. Lonesome7.3
    Jul 21, 2008
    5,061
    987
    Columbus GA
    Yep, those Sterling drum brakes are known to be problems. The rear end is great but the brakes suck. That is why I am swaping in some rear disk brakes.
