1984 mazda b2000
Discussion in 'Mazda Truck Forum' started by Truckiner, Jan 7, 2014.
  1. Truckiner
    Truckiner New Member
    Jan 7, 2014
    Okay so my truck was having issues starting, and the engine would crank but not fully start and then it sounded like the starter somewhat ******* out and slowed down and wouldn't make a noise if I tried starting it again. Idiot me went thinking it was my starter that needed fixing, but the truck would run strong otherwise. The shop then proceeded to tell me the truck was fine at 10 this morning, then told my dad it needed a full rebuild when he picked it up at noon. One of the spark plugs wasn't even plugged in so once I got that taken care of it started right up and idled fine. I shut it off and started it again after 10-20 minutes to see if it still could, and now it will idle at extremely low RPMs and shake the whole **** truck until it just shuts off. Wtf did they do to me? Cause seriously besides starting the truck ran amazingly, and now it's better at starting but now won't idle, and when I throw it in first and try to go for the first 1500 or so RPM (no tach just guessing) has almost no power and I have to floor it to keep it from stalling out. Wtf. any help please
  2. Truckiner
    Jan 7, 2014
    They stuck like part of a pen keeping the carbs butterfly open.....
  3. MrMarty51
    Check and be sure all of the sparking plug wires is hooked to their proper terminals and the proper plug.
    Check the timing.
    Be sure all of the vacuum hoses/lines are hooked to their perspective components.
  4. MrMarty51
    They are the ones that are the idiots, who knowsw what else they might have lost down the carb.
    Sounds like carb. choke they penned open? Maybe check fuel pressure ..and filter.
  6. broke1
    broke1 Full Member
    Nov 4, 2014
    12
    house wife
    Athens, Ga
    I have a 1984 Mazda B2000 as well. When I got the truck it had one vacuum line on it. And I am pretty sure it was not hooked up right.
    It ran from the valve cover over to the spark advance. I got it running. But it had a strange rattling sound from inside the engine.
    I had to replace the head gasket, and to my surprise I found the noise. Someone had replaced the timing chain. But not the gears.
    And when they changed the chain out they left it inside the oil pan. Hey I can not make this **** up. So I put all new head gasket timing gears and chain tentioner. Even went as far as to put a new oil pump and new chain as well. At present it runs but not well. As I said before it only had the one vacuum line on it. And it was not right. So if anyone has a diagram that old idiot like me can read Please let me know.
    Your not a idiot..............this is for b2000 also.
    Click here welcome to the forum..if not right more there.
  8. broke1
    broke1 Full Member
    Nov 4, 2014
    12
    house wife
    Athens, Ga
    Thanks for the reply ! That is for B2200. I got a B2000 it is different. What is hard is there are so many parts under the hood that hook up to vacuum lines. There's one for the spark advance and one perhaps more for a choke. And there is dozens more that have lines running to them.
    But I have no idea as to what they are. Then you have , I know of two vacuum source on the manifold. And there may be more. I am going to need something with a lot of pictures. But thanks anyway.
  9. poncho62
    poncho62 Full Member
    Aug 17, 2013
    816
    1,305
    semi retired
    Hanover, Ont, Canada
    First thing I would do is plug any vacuum sources on the carb and manifold. The line from the vacuum advance on the distributer goes to a port about 1/2 way up on the carb. That should get it running better for you until you can find a diagram
  10. poncho62
    Aug 17, 2013
    816
    1,305
    semi retired
    Here is a diagram...what a mess.
