1986 chevy silverado choke stuck
Discussion in 'Chevy Truck Forum' started by dorgmcsore, Mar 7, 2012.
  1. dorgmcsore
    dorgmcsore New Member
    Mar 7, 2012
    choke light stays on. choke stays on like its cold. even with plate fully open choke is on full blast . idles high smells rich. engine lopes . have to kill it then tap gas pedal to turn off. then backfire. anybodys help appreciated ,thank you
  2. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,763
    214
    Iowa
    Kind of lost me on that... the plate, or butterfly on the top of the carb is the choke.. if its open, the choke isnt on... if its not opening, you can open it manually, put a screwdriver or something large enough that it wont go down the bore to hold it open and start it to see how it runs... I imagine its an electric choke... does it have power with the key in the run position? When the engine starts, vacuum is supposed to crack it open just slightly.. then the electric coil gets hot from the supplied power and slowly opens the choke as it gets warmer... does the choke plate move freely by hand?
    If, as you said, the choke plate is fully open, and its still running that rich, then your float is stuck causing it to run rich/flood...
    bradrhale and Case 7230 like this.
  3. formulabruce
    formulabruce Senior Member
    Sep 29, 2009
    293
    70
    disabled, I do very little but have friends to hel
    Northern New England
    That has an ele choke, unplug it after truck is warmed up. sounds like its shorted causing the choke light to come on.
    Cliff Ruggles has excellent well made ele choke units. Google cliffs high performance
  4. dirtrider73068
    6,650
    4,031
    Unplugging the electric choke won't change anything if the plates are open, if you do unplugged then the choke won't open wouldn't it? I am with oldmech stuck float or something in the carb making it run rich and flood out, also if it still idles high could need adjustment on the high idle.
  5. dorgmcsore
    Mar 7, 2012
    ok plate wasnt "fully "open it was at like 5-10 degrees . open plate is verticle now. started poken my finger around in there and found linkage was binding. so i pushed lever down with my finger,plate goes verticle, , fixed it. but as soon as i hit the gas its stuck again. sprayed wd -40 and carb cleaner still stuck. so for now i just wedged something in there keeping choke from coming on at all . so now it idles normal. choke light still on. tapping gas pedal doesnt disengage choke
  6. dorgmcsore
    Mar 7, 2012
    ya plate starts as you said but doesnt open completly. it does move freelly and when i hold it open while its rrunning didnt seam to do anything. until i pushed this lever down causing plate to open completly and im talkin 5-10 degrees to verticle. just that lil bit choke goes from full blast to off. is that normal?
  7. chengny
    chengny Full Member
    Sep 23, 2007
    377
    25
    Boiler/Pressure Vessel Insp.
    So. NH
    #7 chengny, Mar 9, 2012
    If the dash "choke" indicator is illuminated while the engine is running, you may have low oil pressure - shut down and investigate.
    Do you have an oil pressure gauge? What does it read?
    The power to the electric choke pull is supplied/switched through one of the oil pressure switches. There should be 2 oil pressure senders under/behind the distributor:
    The one with two connections is the one that supplies power to the choke.
    When the engine starts and sufficient is oil pressure developed, (about 10 psi) the contacts within that switch close and supply full battery voltage to the choke heater coil.
    This tells the choke that the engine has started and it's time to open the butterfly.
    See this link (post #43) and the attached pdf's:
    http://www.truckforum.org/forums/gm...uburban-failed-emissions-with-high-nox-5.html
    Also, make sure that there is no gasket between the choke heater housing/carb body and that the cover is tight. That is the ground path.
