1987 350 starts wont idle
Discussion in 'Chevy Truck Forum' started by FamTruck87, Oct 23, 2008.
  1. FamTruck87
    FamTruck87 New Member
    Oct 20, 2008
    I am new to this forum and have a 1987 Chevy silverado 2wd with a 350. A few months ago it died while driving down the road and would not start again towed it home and let it sit. Just got around to working on it this past week. Thought that it might be the fuel pump but there is plenty of fuel getting to the throttle body. So i tried the MAP sensor and it was bad so i replaced that :) and now it will start and run but it will not idle :flamingmad:.
    Ive heard anything from a coolent sensor to just skipping time. Jst thought that i would pick the brains of some of the guys and gals on this forum. Thanks in advance for any advice.
  2. Case 7230
    Could be a vacuum leak. Check vacuum pipes. Could be the Idle Air Control valve needs cleaned/replaced. Could be a EGR valve fault. Pull the vacuum pipe off it and plug the pipe, see if any different. If not then EGR valve may need cleaned. Pull error codes to try to narrow it down. Good luck.
  3. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    levittown pa
    i replaced my egr and iac valve and she started right up... i have an 87 just like yours and was having the same exact problems... hope this helps to get you running again.. its a great truck and i wouldnt let it rot away
  4. FamTruck87
    Oct 20, 2008
    Thanks fellas for the advice that is where ill go with it this weekend. And i totally agree with you slammed, been in the family since new and in 200+ thousand miles this is the first time that it has not run. :applaud:
  5. leolkfrm
    12,436
    7,515
    sensor readings with a scan tool will be more helpful than checking codes, sensors can be out of spec without setting a code
