1987 Chevy 2x4 into a 4x4??
Discussion in 'Chevy Truck Forum' started by frese9, Feb 18, 2008.
  1. frese9
    frese9 New Member
    Feb 18, 2008
    Landscaper
    Quincy Il.
    Hello im new to this site and have a question that im hoping someone here can answer for me. I have a 1987 Chevy truck that I no longer drive but its in great shape and runs perfect, the reason I never use it anymore is because its a 2x4 truck and doesnt work well for my line of work. My question is if its possible to make the truck into a 4x4 because im being told by some friends that people do it all the time. The truck is an auto with a newer 383, a local spring shop here where I live made it a bit stronger a few years ago so I could haul large amounts of weight, if that makes any difference at all.
    Im not someone who could do this work myself but would like to know if its possible and worth paying someone to do for me, this would make a real nice spare truck and a great snow plow truck I believe if its possible. The truck has been torn down to frame about 7 years ago and rebuilt and looks almost new other then the inside that is which isnt too bad.
    Thanks for the help and if you need more info just let me know, looking forward to reading what you all say, thanks agian.
  2. my83432
    my83432 Full Member
    Feb 7, 2008
    Madison, WI
    It can be done but won't be worth it. You would be better off selling that truck and buying another one that allready has 4wd.
  3. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    yaeh it can be done. the easy way is to get a 4x4 (rolling frame) and put the body and motor and tranny on it. but if you want to use your frame the front end will need a little fab work. a little more time and work and money
  4. junior3382
    junior3382 Senior Member
    3,171
    89
    lots of work, and sort of a head ache. For that year, you should be able to find a 4x4, probably even lifted for less money then it would cost you to do a conversion here.
  5. frese9
    frese9 New Member
    Feb 18, 2008
    Landscaper
    Quincy Il.
    Thanks alot guys, I think since its not going to be easy I will just sell it off and go with something different, my other idea was to take the bed off and install a flat bed to put my salt speader on and use it for a salt truck, also thought about putting a plow on it also if the weight of the spreader was on the back was enough to move snow, we only get like 5 inch snow storms around here, most are more like 2-3 inch, just ideas though and if anyone has anyother good ideas just let me know and thanks again.
  6. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    Wrong.
    I did it on a crew cab, Its pretty straight forward. You will need to swap the center section of the floor to clear the shifter for the transfer case. Minor welding skills needed or you can use screws and screw the new center section in like the old Jeeps did. Other option is remove the crossmember from the 4x4 frama and use your current frame (it a pain to do it that way)
