1987 Chevy C-10
Discussion in 'Chevy Truck Forum' started by Skeeter1984, Dec 22, 2011.
  1. Skeeter1984
    Skeeter1984 New Member
    Dec 22, 2011
    I have a 1987 C-10 with the TBI 4.3V6. It does start will run when I'm giving it gas but won't idle. In addition while running if I turn on the lights it will die out. What could cause this problem?
  2. MikeG
    2,317
    1,376
    Richland, Wa
    Sounds like a drain in the electrical system. Might want to look into getting a bigger (for lack of better words) alternator.
    12,306
    7,407
    put a charger on it and see if it stays running
  4. Skeeter1984
    Dec 22, 2011
    Already have new battery and alternator. It even does this when on jumper cables. Any other suggestions?
  5. Case 7230
    Could be a bad/dirty idle air control valve (IAC) or bad throttle position sensor (TPS) or bad/leaking EGR valve. Maybe check for trouble codes as a first step (can do this with a paperclip).
    22,214
    12,851
    Does it start back up without boosting when it quits?
  7. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,762
    214
    Iowa
    do what he said.. sounds like a vac leak bringing the rpm down too far to maintain the load on the alternator.. IAC/EGR cuod cause that.. bad or dead spot in your TPS.. might even be a temp sensor for the computer reading that its really cold even after its warmed up and flooding it.............
  8. leolkfrm
    12,306
    7,407
    when you changed the alternator...did you check all the driven parts to make sure they turn freely?
