1989 Chevy C1500 Steering column question
Discussion in 'Chevy Truck Forum' started by shawn_huk, May 19, 2008.
  1. shawn_huk
    shawn_huk Member
    May 19, 2008
    Im trying to get into my steering column to find out if i can fix or replace the tooth locking assembly for the gear shift. when i pull the shifter back to get out of park and place it into drive, there is quite a bit of play. this happened because the previous owner would rest his arm on the gear shift and eventually it wore away the tooth. i am assuming the tooth locking assembly is in the steering column because its not underneath where the shift linkage hooks into the transmission.
    now my question. ive got the steering wheel off and there is a black plate under neath being held on by a retaining ring and the plate seems to be under the force of a spring. i can push the plate in slightly (1/16") and could possibly (with another set of arms) remove the retaining ring but im not sure what is going to happen at that point. will this actually let me into the steering column or is it just going to spring all apart and leave me with a bigger mess then i am willing to deal with? should i leave this to a shop?
    thanks
    shawn
  2. 87c10slammer
    87c10slammer Senior Member
    Mar 20, 2008
    3,221
    49
    you can remove that without much trouble.i havent gone as far as you are about to but i have replaced the turnsiganl levers and such without much problems
  3. shawn_huk
    shawn_huk Member
    May 19, 2008
    thanks for the reply.
    how do you get the black steering wheel lock plate off? theres a retaining ring holding it together compressed by a spring... im afraid to take this off and have the whole **** thing fly apart.
    how did you get the plate off?
  4. PAPA BEAR
    PAPA BEAR Senior Member
    Mar 1, 2008
    149
    if it is tilt wheel it si a little harder i was trying to get you an exploded view off mitchell but i can not make it happen sorry:(
  5. 87c10slammer
    Mar 20, 2008
    3,221
    49
  6. 87c10slammer
    Mar 20, 2008
    3,221
    49
    i may have a hole column for you if that isnt what your talking about. its out of an 87 c10 but should be the same. but im not really that sure
  7. Chevy_Finatic79
    Chevy_Finatic79 Senior Member
    Mar 30, 2008
    494
    38
  8. shawn_huk
    shawn_huk Member
    May 19, 2008
    yea, so reguardless, im going to need the special retaining ring removal tool to get further into the steering column.
    i can probably make something at work.
    either that, or im going to leave it up to my mechanic.
    thanks everyone for the help.
  9. Chevy_Finatic79
    Mar 30, 2008
    494
    38
    This is the tool you need to press down the lockplate and remove the retaining ring $20 bucks a sears maybe $10 at a parts store
