1989 chevy truck won't start
Discussion in 'Chevy Truck Forum' started by woodman13, Jul 4, 2006.
  1. woodman13
    woodman13 New Member
    Jul 4, 2006
    I have a 1989 chevy truck with a 350 TBI that won't start. It turns over fine and you hear the fuel pump hum, but it won't start. If you dump a small amount of gas in the TBI housing it will start and run fine. The minute you turn the ignition switch off and try to restart it it will not start. The truck has 150K miles on it and it has been well maintained. The problem started a few times here and there and now does it all the time. I have installed a fuel pump and strainer, I rebuilt the TBI and installed a new AIC. I have checked all the fuses and think it is something to do with the injector signal at start up, but I can not find anything on it in my crappy haynes repair manual. Any help would be great.
  2. chevyguy
    chevyguy Senior Member
    Sep 21, 2005
    4,094
    85
    Oklahoma city
    sounds like low fuel pressure to me. Have you checked the fuel pressure, Should be between 13-9 psi any lower and it fuel pump time
  3. 1995C3500
    1995C3500 Full Member
    May 18, 2006
    39
    student/seasonal
    Cincinnati
    a 1992 at work had the same problem last year, it came down to that it needed a new filter, and the lines had to have water pressured through them cause a ton of dirt was in the lines and clogging it and until the engine was started it wasnt pulling enough fuel to run, it would sputter and spit but not do more than fail to start till we sprayed starter fluid down the tbi
  4. 88chev
    88chev Full Member
    May 28, 2006
    35
    are you getting fuel at the throttle body?
  5. Hayden
    Hayden Senior Member
    May 21, 2006
    387
    12
    Bay City,Michigan
    It's junk. wanna sell it? lol
  6. woodman13
    Jul 4, 2006
    It was the ignition modual. I never could find it in my repair manual. I found it on here and just replaced the part. It runs great now, ready for another 150K miles.
