1989 F350 7.3 nonturbo Diesel Start Problem
Discussion in 'Ford Truck Forum' started by AJofArizona, Feb 20, 2010.
  1. AJofArizona
    AJofArizona Senior Member
    Jan 21, 2010
    55
    Military
    Glendale Arizona
    Need some help. I have a 1989 F350 7.3 non-turbo Diesel that doesn't start up in the morning when its cold or hot. have to use starting fluid to get it started if it sits for more than 6 or so hours. Any ideas?:help:
  2. Case 7230
    Sounds like you have an air intrusion problem causing fuel to drain back when it sits for any length of time. The most common cause of this is bad fuel return lines (pipes that run between the fuel injectors). Fitting a new return line kit usually solves the problem.
    Another cause could be bad glowplugs. How long does your Wait To Start light stay on? When cold should be around 10-15secs. Less than that and you could have one or more bad glowplugs.
    Use as little ether as possible, easy to break piston rings on these engines.
  3. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    im with case. glowplugs or does it have an intake heater. not to familiar with automotive diesels.
  4. fuzzy
    fuzzy Full Member
    Nov 3, 2009
    47
    Franklinton, La
    I also agree with Case bad glow plugs or it's losing prime in the fuel system and sucking air.
  5. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    my vote would be something with the glow plugs, either a few bad glow plugs or a malfunctioning controller, but it could be fuel related as well.
  6. robert7642004
    robert7642004 New Member
    Feb 26, 2010
    i just bought a 90 with a 7.3 and it did the same thing. i bought new glow plugs for it and it starts without starting fluid as long as it is above 20 degrees outside. if its colder than that i have to plug it in at night.
  7. leolkfrm
    12,657
    7,766
    i agree with checking the glow plugs, since it starts with the block heater. something else to try is to double cycle the glow plugs before trying to start it, however if there are too many bad ones it won't help
