1989 jeep Comanche running rich help!!
Discussion in 'Other Trucks' started by xxkenny90xx, May 17, 2015.
  1. xxkenny90xx
    xxkenny90xx Full Member
    Feb 20, 2015
    46
    37
    Hey guys, I just picked up an 89 Comanche 4cyl, manual. Basically it has black smoke coming out of the tail pipe, backfires every few seconds, and every 30 seconds or so it revs the engine on its own. The fuel pump and spark plugs are new. I want to work on it this week but was hoping you guys could give me some ideas what to look for. Thanks a lot
    Oh I also pulled the air filter box and sprayed some carb cleaner in and dumped some sea foam in the gas tank (but it runs so rough I haven't really ran it since)
  2. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,022
    2,370
    Fort Wayne, IN
    I would check the timing and the cap and rotor.
  3. xxkenny90xx
    Feb 20, 2015
    46
    37
    Can the timing be adjusted on these by turning the distributor? It looks like the cap is screwed on, can I just unscrew it and check the cap and rotor? (I'm used to older trucks and this set up is unfamiliar to me)
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,022
    2,370
    Fort Wayne, IN
    Apparently the timing is not adjustable. But I would still check all ignition components.
  5. xxkenny90xx
    Feb 20, 2015
    46
    37
    Ok will do, thanks
    Is service/check engine light on? Could be a 02 sensor..coolant temp sensor..fuel regulator.
