1989 Mazda b2200 timing off
Discussion in 'Mazda Truck Forum' started by dumbfounded, Oct 28, 2009.
  1. dumbfounded
    dumbfounded New Member
    Oct 28, 2009
    I changed the timing belt and cannot get it in time. The timing gear has 4 numbers and arrows on it and a "o". I put the "o" at TDC (top dead center) and there was no compression. I played with it and put each number on TDC and I get more compression but it wont run. HELP!
    Oh yeah it has a brand new carberator.
    dumbfounded
  2. mazdawg86
    mazdawg86 Member
    Nov 27, 2009
    timing, ignition, and vacume...... i would check from the coil to the plugs, making sure everything is in the right place. most likely though, it's just not lining up right.... I went through the same thing, my truck sat for months because of it.... it's nice having the non interferance motor. mine ended up being 180 out....
  3. Crmzendrgone
    Crmzendrgone Senior Member
    Apr 6, 2009
    3,218
    found this might help
    Firing order is 1-3-4-2
  4. davbell22602
    Thats a good picture. My buddy is having the same problem. But where is crmzendrgone getting all those good pictures from?
  5. Crmzendrgone
    Apr 6, 2009
    3,218
    shh i have a secrect hiding place not many people have heard of it ssh I tell you [​IMG]
    ssssh:D
  6. davbell22602
    I just thought you had a reference site that has a monthly cost.
  7. Crmzendrgone
    Apr 6, 2009
    3,218
    No, I couldn't afford that.:)
