1991 Chevy 2500 starting problem
Discussion in 'Chevy Truck Forum' started by CowboyCadilac, Jun 8, 2011.
  1. CowboyCadilac
    CowboyCadilac Full Member
    Jun 8, 2011
    Minnesota
    I have a 1991 Chevy k2500 with a 5.7 tbi. It just happened the other day where the truck just shut off like I turned the key off. Then finally got it running and it ran fine for a couple days and then happened again. Had it towed home and today put a new fuel pump and fuel pump relay and got it to start 2 times but then died and now won't start again. Does anyone have any idea where to go next?
  2. kronhenry
    kronhenry Senior Member
    Apr 21, 2011
    211
    15
    Welder
    Tennessee
    did you replace the fuel filter
  3. CowboyCadilac
    Jun 8, 2011
    Minnesota
    I did not replace the fuel filter. Wasn't exactually sure if the fuel filter could cause it to do that? It also when u turn the key is not shooting gas out of the injectors. So I guess maybe it could be a plugged fuel filter.
  4. kronhenry
    Apr 21, 2011
    211
    15
    Welder
    Tennessee
    or it could be the icm check to see if you have spark. the icm controls the injectors and the spark and they love to fail
  5. CowboyCadilac
    Jun 8, 2011
    Minnesota
    I bought a fuel filter for it today. Don't have time yet to get it put in so will post after I get it put in tomorrow. Thanks for all the help. Forgot to ad that I did go out today after it sat all night and tried starting it and it started right up. Ran for about 30 secs and then just like I turned the key off and died and wouldn't start again.
  6. kronhenry
    Apr 21, 2011
    211
    15
    Welder
    Tennessee
    try unplugging the temp sensor and starting it. its located next to the top radiator hose on the manifold
  7. CowboyCadilac
    Jun 8, 2011
    Minnesota
    Got the new fuel filter in tonight. Started up after priming the pump a few times. Ran for about 30 secs and died again and wouldn't start back up. Waited about 5 min and it started again and did the same thing over. Now it won't start again. Tried umpluging the temp sensor and starting it and still didn't start. So is my next option to replace ICM?
  8. kronhenry
    Apr 21, 2011
    211
    15
    Welder
    Tennessee
    try testing the pressure at the tbi i think it should be between 12-16 psi if you get good pressure and it still doent put out from the injectors my next thought would be icm there pretty cheap
  9. chevychase
    22,406
    13,169
    When it will not start pour some fuel in throttle body.... if still no crank check for spark at the plugs... then at coil.
    If not probably be icm or pickup coil. Check resistance on the icm and pickup.
    If you get 800 to 1200 ohms of resistance they are good.
    The pickup is a old school / type of crank sensor.
  10. CowboyCadilac
    Jun 8, 2011
    Minnesota
    Ok so I bought the ICM today and not sure how to put it in or where it goes. Can anyone give me a heads up on how to install it?
