1992 GMC TBI to Carb
Discussion in 'GMC Truck Forum' started by Bama Phil, Mar 7, 2010.
  1. Bama Phil
    Bama Phil New Member
    Mar 7, 2010
    Mobile Al
    New to the site,been lurking for a while .I have a 92 GMC reg cab,5.7 with a 5 speed manual trans,160,000 miles,not my daily.I know this has been discussed before but here goes,I have a 350 motor already built with a 650 Holly carb I'm planning on swapping out complete,I know I'm going to have to put a fuel regulator on it,I'm thinking the 5 speed manual trans should work(correct me if I'm wrong),How hard will it be to bypass the computer and will my fuel,speedometer and RPM guages work when I do?I know everyone is going recommend swappin the TBI but I want to stay with the carb,just my preferance.This is a great site thanks in advance,
    Bama Phil
  2. silverhairdeere
    silverhairdeere Senior Member
    Feb 15, 2008
    1,831
    33
    disabled
    land between the lakes tn
    #2 silverhairdeere, Mar 7, 2010
    IF THEY DON'T HAVE INSPECTIONS , try this
    link removed by mod
  3. davbell22602
    winchester, va
    welcome to the forum.
  4. Bama Phil
    Mar 7, 2010
    Mobile Al
    Thanks guys,I've been reading the site for quite a while picking up on a lot of helpful info,I'm not as knowledgeable(if thats a word)as alot of folks on here but hopefully one day I'll be able to pitch in.
    Thanks again
  5. scavanger
    scavanger Full Member
    May 15, 2007
    1,730
    1,289
    What are your plans with the distributer? Going with an old style HEI ? You might have to unhook the check engine light. If you transfer the sending units the gauges should work.
    Scav.
  6. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    not that big of an issue. i have 92 chevy with old style engine. as stated, just change out senders so guages will work. i ran engine with 92 dizzy for a while and changed to old style hei. had to put fuel bypass regulator on carb to lower fuel pressure. put fuel pump block off plate where old pump was but ive heard you can run mech pump with return line. just have to add to existing fuel lines. and yes your check engine light will stay on. just remove bulb or put a piece of black tape over it. i just ignore mine. that manual tranny should bolt right up. ive got a few pics on my profile page. have a look.
  7. gmctrucks
    8,584
    4,175
    Welcome to the forum and howdy from TEXAS. Your going to like it here it's one clean site to where kids are even on it which I think is alright. I say put on some good heads and a slight cam to where you can hear it before you put it in.
  8. Bama Phil
    Mar 7, 2010
    Mobile Al
    I 'm going with a HEI distributor.
  9. gpmorgan
    Nov 21, 2009
    2,687
    288
    83
    Tupelo Ms.
    good choice. just hook your tach wire to the tach post on cap. should work just fine. after putting on MSD ign i had to use tach signal from MSD. still no problem.
