1992 Toyota Truck cold start problem
Discussion in 'Toyota Truck Forum' started by floridastate, Jan 18, 2011.
  1. floridastate
    floridastate New Member
    Jan 18, 2011
    1992 4x4 22r, efi, won't start when its really cold outside. It cranks fine when its warm out, even it has sat for days. On cold mornings it turns over fine, may even act like its going to start, but won't. I can crack open the air filter canister, spray a little either at the edge and it will crank up fine, idle fine and crank the rest of the day. The next morning if its cold out, the same thing. Help! Thanks.
  2. TexasAirCooler
    TexasAirCooler Senior Member
    Feb 7, 2010
    139
    Check your cold start injector.
    When was the last time you ran some injector cleaner through the tank?
  3. floridastate
    Jan 18, 2011
    cold start injector
    How do I check the cold start injector and where is it located? I ran injector cleaner through it a few months ago.
  4. TexasAirCooler
    Feb 7, 2010
    139
    Looks like it's time to buy you a repair manual, Chilton and or Haynes.
  5. sparkyT
    sparkyT Member
    Jun 20, 2011
    The cold start injector is mounted to the upper air intake manifold just above the level of the valve cover. It's more likely that the cold start switch or it's connector has gone bad. At this point you really do need a service manual to correctly troubleshoot this circuit.
  6. had5050
    had5050 New Member
    Dec 29, 2011
    got an88 donebe the same thing replaced cold start injector and cold start timing sensor no help but i changed the fuel pump and it seems to be working now the strainer was gone off fuel pump
  7. alem124max
    alem124max New Member
    Feb 1, 2012
    Many cars doesn't start in cold days, but in Asia where less cold cars starts easily. I have Toyota Tundra 2008 model and sometime it creates problem to start.
