1993 GMC Suburban No heat
Discussion in 'Chevy Truck Forum' started by lclhawnboy, Jan 17, 2012.
  1. lclhawnboy
    lclhawnboy Member
    Jan 17, 2012
    I have a 1993 GMC suburban and the heater doesn't work. I hear the blower motor turn when I turn the key to ignition. I also don't see any lights on the air controls also air controls don't work. Any suggestions?
    Check fuses to start.. Maybe head unit /control panel. Check for power at unit.
    Will try to find a wire diagrahm.
  4. UncleBigBad1968
    UncleBigBad1968 Senior Member
    Dec 30, 2011
    249
    ne ok
    If your thermostat is working, you can feel your heater hoses going into the firewall, both should be realitivley warm. You wont be able to hold on to them for a few min, cuz it will/should be slightly too warm to hold. If one is hot, and the other is cold then your heater core is clogged. Try to flush it first.
  5. dirtrider73068
    6,441
    3,854
    If the heater core is clogged best to just change it, if you try to flush it may bust the heater core thus making it leak. Can you change form vent to defrost to floor if so your controls are fine, then the issue comes to the mode door, there are 3 the heat/cold door could be messed up, chevy's are known for this from what i have read, Ihave this issue, a gear inside cracks and gets stuck or won't work, your temp adjustment arrows should flash if this happens. If thats the case its about 100 buck for that mode door motor, but if you can get it out, take it apart the main gear that is/if cracked can be removed turn 180 degrees and put back together to work to get by, this I know did it to mine.
  6. lclhawnboy
    lclhawnboy Member
    Jan 17, 2012
    Thanks I checked the heater fuse and it was fine. So next step change the thermostat.
  7. lclhawnboy
    lclhawnboy Member
    Jan 17, 2012
    Thanks I checked the heater fuse and it was fine. Next step change out the thermostat.
  8. formulabruce
    formulabruce Senior Member
    Sep 29, 2009
    293
    70
    disabled, I do very little but have friends to hel
    Northern New England
    AT least take off the heater hoses and blow through them, please???
  9. dirtrider73068
    6,441
    3,854
    You don't have to blow through the heater hoses, all you need to do is feel of the hoses hen the truck is warm will tell you just as better.
  10. UncleBigBad1968
    Dec 30, 2011
    249
    ne ok
    Never had a leak after I flushed mine. But in case it does then replace it. Might as well save a few bucks, and a headache. It is not easy pulling that dash apart to change the core.
