1994 GMC C1500 battery drain
Discussion in 'GMC Truck Forum' started by jgraham37128, Jan 1, 2013.
  1. jgraham37128
    jgraham37128 Full Member
    Dec 30, 2012
    22
    Ok guys for years I've had a battery drain on my 1994 GMC C1500. If you start it every 3-5 days it's fine but left for a week or two and the battery will be dead. I've looked around and done some testing but really never found anything that I would consider enough to be the problem. I've done the fuse puller idea and looked for sparks but nothing really stood out. Can someone lead me in the right direction to start?
    I will give you some info. I bought this truck brand new so I know every part that has ever been replaced. For the most part it is completely stock. I did have an amplifier added back when it was new. I've also disconnected this amplifier first to see if this was the problem and the battery still drains after a week so I'm going with this isn't what is causing the battery drain. I have a volt meter but really not knowledgeable on exactly how to use it.
    thanks,
    JG
    22,214
    12,851
  3. Boudin
    602
    That video link that Chevychase posted should get you fixed here. It could be a number of things and can come out of nowhere. Using the approach above will certainly help you find the problem. Just remember to keep your mind open to the cause here and certainly consider that the battery might be the cause. If it were me, I would first test the battery with your multimeter by simply testing the voltage at the terminals. If the battery is 100% charged....you should see a solid 12.6 volts on the multimeter.
    Based on what I can think of here....you either have a parasitic drain (like an underhood light that won't shut off when you close the hood)....or you have a battery that is unable to be charged fully. All I am saying is that based on your description of what it going on....don't be so quick to say it is certainly a parasitic drain.
  4. dirtrider73068
    dirtrider73068 Moderator
    6,243
    3,680
    I would have the battery tested, if its still good then look at the power drain. Do you have a power cap hooked up with the amp? Might disconnect that, if its bad it could draw current trying to stay at full power.
  5. jgraham37128
    Dec 30, 2012
    22
    I'm going to totally disconnect the amp when doing my test.
  6. jgraham37128
    Dec 30, 2012
    22
    For some reason it won't let me upload any pics? Can anyone help? When I click on Manage attachments it pops up but then turns all grey?
    22,214
    12,851
    Left pm to administrator on this . I can not even post any . Maybe senior mod. mudseeker he is the pro. can look into it.
    Others for awhile have been having trouble.
  8. dirtrider73068
    6,243
    3,680
    Can you upload to a place like photo bucket then post the links here.
  9. chevychase
    22,214
    12,851
    no i tried all
  10. renegade1957
    renegade1957 New Member
    Nov 18, 2012
    do you have courtesy mirrors on the visors?
    women use theirs alot more than the guys do. mine was sagging just enough on her side to cause the light to be on when it appeared to be closed. worth a check.
