1994 k1500 - help ...no brake lights
Discussion in 'Chevy Truck Forum' started by duramac, Jan 31, 2008.
  1. duramac
    duramac New Member
    Jan 31, 2008
    #1 duramac, Jan 31, 2008
    94 1500 4x4 just pulled truck into shop ,no brake lights,,both left and right turn signals work fine.blew a fuse when turning on 4 way hazard lights, change fuse and still no brake lights,,where do i satrt with this one?
    if turn signals are working then the bulbs are ok.the fuse it blows is the stop hazard fuse think its number 1 in the fuse box,maybe a short or brake light switch?
  2. junior3382
    junior3382 Senior Member
    3,171
    89
    Do the parking lights work along with the turn signals and 4-ways?
  3. 436'd skylark
    436'd skylark Senior Member
    1,143
    Mac Tool Distributor
    Pennsyltucky
    multi-function switch...
  4. crabtruck
    Welcome to the forum duramac.
    You are right on the bulbs being ok. Thought the stop fuse was bottom center.
    Pull the hazard flasher out (not turn flasher), replace the 15A fuse.
    Verify turn signals work. Check that fuse does not blow and high stop light works.
    If not I would suspect you have water in your high stop lamp fixture.
    If it does work, bad haz flasher or turn/haz combo switch as Joe suggested.
    Or something in the wiring connecting them shorting (brown wire)
  5. brandoj
    brandoj New Member
    May 15, 2007
    Field service engineer
    Oregon
    My 94 Silerado had the same problem. I believe It was a recall back in the day. Brake switch under dash near the brake pedal OR check yer wiring harness at rear end. I "accidently" bolted a hitch to my harness and created a short there.
  6. crabtruck
    I believe the recall was for "wrong polarity" on the wiring to switch and the possible hazard was fire. Should work fine until that point.
  7. 340doc
    340doc Full Member
    Jan 30, 2008
    My 97 has a fuse box under the hood also ,with another brake light fuse.
  8. crabtruck
    94's didn't have fancy underhood fuse boxes LOL Only fuse there was fuel pump.
