1995 chevy k1500 - Which Rear differentials interchange ?
Discussion in 'Chevy Truck Forum' started by Douglass, Mar 20, 2011.
  1. Douglass
    Douglass Senior Member
    Jan 1, 2011
    87
    I need help again, I have a 1995 chevy k1500 5.7, and I need to know
    what rear end assemblies will work/interchange with my truck.
    I called the dealer and I was told that 3:73 gears came in the truck.
    any help would be great,
    I am going to the pick yard this next weekend and need to know what will work.
    I am about 95% sure it has a 8.5" rear end.
    I would like to be able to buy a complete rear end and simply install it into the truck.
    thanks,
    Douglass
  2. Saugeen Drifter
    Saugeen Drifter Senior Member
    Jul 23, 2009
    219
    is this a 2wheel drive, if it is any gear ratio will work, its simply a swapping of gears,
    if its a 4x4 you must ensure your rear pot gear ratio matches that of your front pot "diff".
    There is a previous post I answered to called "rear end", it states where to find
    your rear end information and what the codes in your glove box mean
    and I think they differentiate the rear ends for our years of trucks by the number of bolts that hold on the rear differential cover not its diameter. It should be a 10bolt or you have the size of 8.5" correct
    One recommendation, pull off the differential cover and make sure its a limited slip not a full slip,
    limited is by far more desirable unless you want to drag it then you want a non slip.
    full slip = if one rear tire slip spins the other is a dud and just sits there
    limited slip = if one tire starts to slip spin the second tire will be actuated and begin to spin,
    perhaps getting you unstuck or giving you more traction
  3. Douglass
    Jan 1, 2011
    87
    this is a1995 1/2 ton 4x4. I am looking to see what rear ends can be bolted up with out modifications. I am not going to be picky on the differential or even the brake size. can any 89-98 1/2 ton 4x4 be bolted on? Thanks for the help guys I need to know what will work when I go to the pick yard. I am looking for a complete rear end assembly, not just the differential.
    Douglass
  4. Douglass
    Jan 1, 2011
    87
    Ok guys anyone know about rear ends that would inter change with my truck. How about rear differentials. I am going tomorrow to the pick yard any advice would be great. ? I read the tread you were referring to. i am looking for a year range.
    Douglass
  5. Douglass
    Jan 1, 2011
    87
    I wanted to update this, I found a 1989 Chevy K2500 in the pick and pull yard, and it had a 14 bolt rear end 3.73 posi 9.5" ring gear6 lug. It cost me 159.00 with drums. I installed new brakes shoes, new lift blocks w/u-bolts and nuts, machined the drums, new hardware,new wheel cylinders,new axle seals, and a new brake hose too. It bolted right up to the truck. i had to make a parking brake cable adjustment, and had to buy a conversion u-joint. I have the truck bed off replacing the fuel pump for prev maint, but once I drive the truck I will update the thread again.
    the rear end that was in the truck originally was a 8.5" 10 bolt.
