1995 chevy manual transmission fluid?
Discussion in 'Chevy Truck Forum' started by jennifer_rose, Jan 12, 2010.
  1. jennifer_rose
    jennifer_rose New Member
    Jan 12, 2010
    whats the name of the manual tranmission fluid for a 1995 chevy pickup 5speed. my book says GM 1052931 man. trans. fluid or equivalent, a few people told me ATF, which seems crazy for a manaul & i've also read gear-oil 75-90??
  2. davbell22602
    winchester, va
    manual uses hydro fluid like same fluid in a hydro clutch.
  3. jennifer_rose
    Jan 12, 2010
    ?? so the same fluid that i put in my clutch cylinder
  4. leolkfrm
    12,436
    7,515
    use the gm part # it has special additives so you don't smell the oil when it gets warm
  5. leolkfrm
    12,436
    7,515
  6. jennifer_rose
    Jan 12, 2010
    gm1052931 does not mean anything to the chevy department. it pertains to a part not a fluid. he said some fluid that started w a S?? sorry cant remember. i want to know if i can go to advance auto or orielys and get an equiv. and if so what is it. ive been told like 4 dif. things now
  7. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    might call a trans rebuild shop. they should know.
  8. semocoachworks
    semocoachworks Senior Member
    May 6, 2009
    967
    Maintenance Manager for a 60 truck fleet and 4 loc
    rapid city, sd
    These are the ONLY lubricants recommended for the NV4500:
    • 75W-90 Castrol Syntorque Synthetic
    • Mopar Manual Transmission Lubricant (PN 4637579)
    • GM Transmission oil (PN 12346191)
    • NOTE: Syntorque is NOT the same as Castrol Syntech
    This is for the nv4500 5 speed. If it's a new venture, it will have a tag on the side telling correct fluid. If you do not use the correct fluid, it WILL result in failure as these have a paper type coating on the synchros.If it is a nv3500 ,HM-290/5LM60 5-speed manual transmission - Synchromesh transmission fluid P/N 12345349
  9. hotrodpc
    hotrodpc Full Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    This is the correct info right here. NO, Not clutch fluid. For clutch slave and master cylinder fluid, I do believe you can use Dot 3 brake fluid. But I didn't tell you that.
  10. jennifer_rose
    Jan 12, 2010
    Thanks for everyone for the help
