1995 Chevy s10
Discussion in 'Chevy Truck Forum' started by Eli Trippet, Jan 6, 2017.
  1. Eli Trippet
    Eli Trippet New Member
    Jan 6, 2017
    My brother has a chevy s10 1995 and the 4 wheel drive won't work. The light comes on but it won't engage. I looked at the fuze and its fine and when you press the 4X4 button you can hear something like its trying to engage but it just won't work.
  2. scavanger
    scavanger Full Member
    May 15, 2007
    1,779
    1,340
    is the front axle locking? if not the driveshaft will turn but not give you 4 wheel drive. I think the S10 front axle locks with vacuum to an actuator usually under the battery and a cable to the axle.Could be as simple as a broken vacuum line.
    Kennyray likes this.
  3. Eli Trippet
    Jan 6, 2017
    . Sweet thanks, I don't think it is locking so I'll take a look at that line and then replace it
  4. Kennyray
    Kennyray Moderator
    Oct 6, 2005
    2,028
    2,374
    Fort Wayne, IN
    They are known for the vacuum line to fail because it is routed directly under the battery.
