1997 K3500 4x4 stuck in the mud!
Discussion in '4x4 trucks / off road' started by 97k35004x4, Nov 19, 2011.
  1. 97k35004x4
    97k35004x4 Full Member
    Nov 19, 2011
    I'm new to the 4x4 world, and today after going to ranch and getting stuck was not fun! I'm determined to not have this happen to me again! I bought the truck two weeks ago and today I tried putting in in 4L nothing happen. It's manual on the floor with I assume it's auto locking hubs. When placed in either 4h or 4L the lights on the floor did not light up on the front axle!
    1. I checked fuse in door and checked good. Placed a new just be sure
    2. Checked fluid level was a little low but overall ok. (what king of fluid should I use in the front axle)
    3. ?
    This is where I'm lost. Could use any advice. I would appreciate the help! Tomorrow I'm off and would be a good day for me to work on it!
    Thanks,
  2. 97k35004x4
    Nov 19, 2011
    Bump, thanks
  3. dirtrider73068
    dirtrider73068 Moderator
    6,244
    3,683
  4. 97k35004x4
    Nov 19, 2011
    Thanks, I just need help locating the Ball switch and transfer case switch.
  5. dirtrider73068
    6,244
    3,683
  6. dirtrider73068
    6,244
    3,683
    Alternative Discussion: 4X4 Wiring
    This one too talks about a time delay relay to engage 4x4 its under the hood, might see if you have something close to it. I just googled your truck 97 k3500 won't engage 4x4 and found these links.
  7. 97k35004x4
    Nov 19, 2011
    After tomorrow I'll replace to actuator and then let you know! Cross your fingers for me
  8. dirtrider73068
    6,244
    3,683
    Before you replace it talk boards say take it off, engage 4x4 and see if it moves to make sure its bad before replacing.
  9. 97k35004x4
    Nov 19, 2011
    I just remove it, keep it plugged in and have someone put the truck in neutral and switch it from 2h to 4l??
  10. dirtrider73068
    6,244
    3,683
