1998 1500 chevy starting problem-popping p1626 code?
Discussion in 'Chevy Truck Forum' started by craigchaselisa, Mar 17, 2009.
  1. craigchaselisa
    craigchaselisa New Member
    Feb 22, 2009
    Need help fellas.....
    Have replaced spider injector,fuel pump, newly programmed computer, etc on this 98 silverado 2wd with 350 v8.....the security light stays on constant but will not run on its own but will if you spray it with carb cleaner
    tried turning the key on and waiting for 10 minutes to reset code....same prob
    scanner states the p1626 code and that the security system not linking same password to the VTD??
    ANY SERIOUS IDEAS ON HOW TO FIX OR TO GO ABOUT BYPASSING THE SECURITY SYSTEM?
    12,309
    7,414
    Welcome to the forum
    Who programmed the computer?? and is it a stock program? are you using a scanner or a code reader?
  3. craigchaselisa
    Feb 22, 2009
    thanks for responding
    the local junkyard programmed the stock computer...they coded it to match the vin#,etc....and we are using a snap on scan tool
  4. mudseeker
    580
    does the key have a chip on it? try a different key and see if the problem changes.
  5. leolkfrm
    12,309
    7,414
    I remenber posting the reset process somewhere, no time now I'll look later.
  6. craigchaselisa
    Feb 22, 2009
    ok thanks....to the other person asking about the keys....there is no chip with the keys i have...i wondered the same logic....but thanks for the suggestion i really appreciate it
