1998 ford ranger low fuel pump pressure
Discussion in 'Ford Truck Forum' started by rovi, Mar 8, 2012.
  1. rovi
    rovi New Member
    Dec 18, 2011
    ANTIGUA,WEST INDIES
    Does anyone know what pressure should be at the injector rail of the 1998 ford ranger with a 2.5litre engine?
    22,406
    13,171
    Should be at least 64 psi..and hold this pressure
  3. rovi
    rovi New Member
    Dec 18, 2011
    ANTIGUA,WEST INDIES
    what can cause the engine to idle very eratically and to have low power?
    22,406
    13,171
    Are you getting a service engine light? Could be many things ..electrical or fuel.
  5. rovi
    rovi New Member
    Dec 18, 2011
    ANTIGUA,WEST INDIES
    no im not getting a service engine light
    22,406
    13,171
    Seems light ought to be on...does it work ? When you turn key on..does light come on then go out?
    This is a 4 cylinder try changing the plugs..if just one is bad will make engine erratic.and not have power.
    Could be a plug wire..check fuel filter. without a check light hard to diagnose.
  7. tireboy
    tireboy New Member
    Apr 16, 2012
    Hi sir! i have a problem with my fuel pump.. I replaced my fuel pump, sending, unit and regulator, after new oem pump installed
    and tank cleaned of severe filth the operating pressure at idle is 27psi and 26 psi under load of 2000 RPMs or higher. New fuel filter only ran for 1 or 2 tanks under filthy gas tank (previous filter was clogged enough to block pressure to 12psi on key flick) and pressure on key flick comes up to 38 psi before starting engine. Spec operating range is 30 - 45psi.
    Since the operating pressure has gone down since new ford truck parts has been installed and given all the new fuel system items what could this mean is wrong?
