1998 honda crv dumping water
Discussion in 'Other Trucks' started by sazquatch, Jul 27, 2014.
  1. sazquatch
    sazquatch Full Member
    Jul 13, 2014
    30
    I have a 98 honda crv awd it just started pouring water from motor it doesnt do it constantly it will stop then acouple min later will start again cant see wear its coming from any suggestions
    Seems a problem on these crack in the top of the plastic upper radiator housing..maybe.
    Reason it pours then stops..building up pressure..leaks..then cools down some stops.
  3. sazquatch
    Jul 13, 2014
    30
    I can se it coming from the motor on the oppside of waterpump and not from hoses or thermostat
  4. sazquatch
    Jul 13, 2014
    30
    Icant see where its coming from but it looks like its def coming from the top backof motor
  5. BurbanMan
    BurbanMan Full Member
    Jul 22, 2014
    1,230
    990
    Stove tech @ true value
    Cortez, CO
    If belt side of motor, Water pump has taken a dump. It's driven by the timing belt.
    Top rear? I'm willing to bet its a freeze plug. The b series engine are pretty bullet proof unless you think it's some sort of race car
    chevychase likes this.
  6. sazquatch
    Jul 13, 2014
    30
    It is pretty fast for a man van lol but it is coming from below air intake maniold
  7. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
    Pull tht stuff of of there and snap some photos to refresh my memory. It's been a while since I had my b
  8. MikeG
    2,800
    2,070
    Richland, Wa
    Is it clear water? A/C Condenser................?
  9. chevychase
    Flashlight time.and some snooping.
    Could be the intake gasket..behind engine will have a coolant pipe with orings??
  10. BurbanMan
    Jul 22, 2014
    1,230
    990
    Cortez, CO
    I don't believe it does if I remember correctly.
