2000 F250 Superduty speedo abs problems
Discussion in 'Ford Truck Forum' started by bobm1965, Feb 23, 2007.
  1. bobm1965
    bobm1965 New Member
    Feb 23, 2007
    I have a 2000 F-250 Superduty with the Powerstroke.The speedo quit,the abs quit,over drive light flashes,and the cruise doesn't work.All happened at the same time.I changed the speed sensor didn't help.Took it to the dealer and they said it was the abs module.I changed that, still didn't work. Does anybody have any ideas what the problem might be.Also checked the wiring it was all ok. I'm at a loss.
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Have you pulled the codes yet? If the OD light is flashing there is a code. Not sure if it would have anything to do with the speedo or abs. I would say speed sensor but you already changed it.
