2000 K3500 PRNDL lights issue
Discussion in 'Chevy Truck Forum' started by stftruck, Feb 7, 2009.
  1. stftruck
    stftruck Member
    Feb 7, 2009
    I have a problem with the PRNDL lights. P & L light up when in gear but RND32 quit lighting up yesterday. Trans works fine (4L80-E). All other lights work fine. No blown fuses. Anybody ever see this before? Any suggestions? 2000 K3500 Crew 7.4L Auto 56K. Thanks, stftruck
  2. stumpuller454
    Dec 26, 2007
    2,206
    65
    can`t say i`ve seen that before in the OBS trucks, its pretty easy to remove the cluster and have a look at the lights back there, maybe some silly plastic peice broke and is covering the bulbs, got any picks of your truck?
    I know on the NBS trucks the PRNDL switch on the trans causes the lights in the dash not to work sometimes, most comonly anyways, but they are $$$$ to guess at this point.
  3. stftruck
    stftruck Member
    Feb 7, 2009
    Thanks, I already looked at the range selector. Plug for feed to cluster is clean inside & nothing broken. Looks like I need to check the cluster for anything obvious. Maybe I can test the lights & feed from range selector. I tried to attach a picture...we'll see if I succeeded.
  4. stumpuller454
    Dec 26, 2007
    2,206
    65
    SWEET truck! i WISH i had a crew cab, you`ve got some low miles! i`m at 60k myself, and trying to finish up this supercharger.....[​IMG]
  5. stftruck
    stftruck Member
    Feb 7, 2009
    Thanks! I bought it @ 14k about seven years ago. My first Chevy truck. I'm impressed with it. Real nice ride for a 3500!! With the 4:10's I only get 11-12.5 MPG. With or without a load. I can't see the expence of installing 3.73 gears. Just have to live with it.
  6. stumpuller454
    Dec 26, 2007
    2,206
    65
    yeah best i could get before tuning was that, but was getting 13-14 city this summer, my trucks alittle bit smaller though. and I`m sure I`ll be in the single digits this summer.....:)
    have you changed your factory muffler? biggest gains in mieage was from getting a catback system with my truck...
  7. stftruck
    stftruck Member
    Feb 7, 2009
    Everything is bone stock. I put on one size bigger tire when I changed out the orignals though. Barely any room up front to clear those. It had a Debut conversion added from the factory. Lucky for me it did not have those fiberglass flares all the way down the side they always seem to add. Just a set of real SS step tubes & they painted the factory flares white to match truck. Also one of those lift up soft tonnue covers.
