2000 Silverado 4.8 LS, Serpentine Belt
Discussion in 'Chevy Truck Forum' started by gonmoises, May 13, 2011.
  1. gonmoises
    gonmoises Senior Member
    Feb 18, 2011
    61
    I just replaced the serpentine belt on my 4.8 V8. How do I know if the belt is to tight?
  2. MikeG
    2,338
    1,408
    Richland, Wa
    As long as the spring in your tensioner pulley is operating properly, the tension will be where it needs to be.
  3. gonmoises
    Feb 18, 2011
    61
    this is the thing,, the tensioner after replacing the belt has maybe 1/4" of slack left. Meaning if i need to remove the belt thats how much it would release to get the belt off. I am thinking the belt is too tight.
  4. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    410
    47
    detention officer
    bozeman mt
    they are tight for a while wait a couple of days and check again they do stretch
  5. MikeG
    2,338
    1,408
    Richland, Wa
    Not to insult anyones intellagence, double check to make sure the belt is placed on all the pullies correctly. I've done that myself and had slack left in the tensioner. New belt or not the tensioner shouldn't have any play in it; unless the spring is bad. I'm trying to get on the Chilton Library to pull up a diagram but the Military site is down right now. I"ll keep trying to get on and post a diagram.
  6. MikeG
    2,338
    1,408
    Richland, Wa
    Got you the diagram:
    Belt Routings
    Accessory serpentine belt routing—4.8L, 5.3L and 6.0L engines
  7. gonmoises
    Feb 18, 2011
    61
    got it thank you,
