2000 Silverado 4x4 making a squeaking sound
Discussion in 'Chevy Truck Forum' started by tcanthonyii, Mar 31, 2010.
  1. tcanthonyii
    tcanthonyii Member
    Mar 31, 2010
    Hey all. I was referred here from a motorcycle message board I'm a member of and said you all could help. I'm no mechanic but have mechanical abilities. I or my friends and I usually do all of our own work. We're cheap I've put motors in cars torn rear ends apart etc. I've got this problem that I cannot track down and it's pissing me off.
    Only when moving forward can you hear a squeak squeak squeak noise. It's almost like a rubber on metal sound and is bases almost on tire speed and more so under load. It gets very quiet when you are not on the foot feed. I've jacked the truck up and had all 4 corners on stands.
    #1 When I turn the rear drive shaft when the truck is in 2wd the front shaft spins. I've been told that isn't supposed to happen.
    #2. When doing number 1 if you spin the shaft as if the trick was moving forward there is a slight squeak noise. I dropped the front shaft off of the differential and the the squeak is coming from the front of the transfer case.
    What does this mean and does anyone have a clue as to what the fix is and can myself and my friends do it? My one friend was a Humvee mechanic in IRAQ so he has good knowledge as well. This one is just baffling us.
    T.C.
    12,428
    7,514
    welcome
    it is normal for the Front shaft to spin
    sounds like a u-joint, the noise may be traveling
    have you tried using a piece of pipe as a listening bar?
  3. tcanthonyii
    tcanthonyii Member
    Mar 31, 2010
    Yup. Out of the transfer case.
    T.c>
  4. fordson
    fordson Senior Member
    Mar 6, 2009
    298
    local truck driver
    south west virginia
    welcome to forum leolfrm is right the front shaft does turn it quits turning @ a certain speed and i would say he is also right on the ujoint the noise is traveling through the rear shaft or could be the one @ the transfer case.
  5. tcanthonyii
    tcanthonyii Member
    Mar 31, 2010
    Would it be traveling all the way through the rear shaft and transfer case though? Seems unlikely. How does that boot come off of the front of the trans case so that I can inspect that joint there?
    T.C.
  6. 75K30
    Boot???? What boot? There should be a flange that is on the front of your t-case. That boot should be covering the slip joint.
    Have any pics?
  7. chevy_girl_85
    chevy_girl_85 Senior Member
    Feb 3, 2010
    612
    11
    auto technician
    Reno, NV
    Are you talking about the front driveshaft boot? If so that is usually a sealed unit and not made to be taken apart
  8. pinkpanther
    pinkpanther Member
    Mar 22, 2010
    Semi-retired
    Okanagan.Canada
    Replace the rear u joints. Don't go looking for bigger problems, this is the cheapest place to start. They dry out and start squeaking.
  9. 75K30
    Actually the opposite is true. They have to come apart to be serviced. In many cases noise can come from this area when the splines become dry.
    Many mechanics (I do) own a banding tool that replaces this stainless steel band that holds these on.
    While it may appear that they are not a service item, they are not sealed, and require some attention.
    More times than not, I remove the rubber boot and throw it away. Ive found that these things trap water and dirt, and do more damage than good.
    Just a FYI, but I think we might be talking about the same components as the OP.
  10. tcanthonyii
    tcanthonyii Member
    Mar 31, 2010
    Bingo you got it. So I can pitch it then w/o having a problem? I may do that then and drop the whole shaft. Will I loose any fluid out of the front of the xfer case if I pull that off? I know on a tranny you will sometimes. Just making sure. My buddy exercised the shaft a couple of times before we put it back on the other night and now the noise doesn't start for the first 1/10 of a mile or so.
    T.C.
