2000 Silverado won't start in cold weather
Discussion in 'Chevy Truck Forum' started by cheaptric, Dec 16, 2008.
  1. cheaptric
    cheaptric Member
    Apr 6, 2008
    About a month ago my truck would not start on cold mornings. The engine would turn over fine but seemed to not be firing. After replacing the Temperature Coolant Sensor truck started with no problems for the last month. This morning was a very cold morning and my truck would not start again. Engine turns over but does not try to start. No sputtering, nothing. Codes have been checked and nothing is being reported. I can hear the fuel pump run when key is first turned on. Any help or suggestions would be greatly appreciated.
    12,657
    7,766
    Did you check codes or have a proper scan? Scans are better because they show weak parts that don't throw codes. temp sensors are a common problem for cold starts, but it sounds like a good scan is needed
  3. SS2007
    SS2007 Full Member
    Dec 8, 2008
    25
    You should check the fuel filter.
  4. cheaptric
    cheaptric Member
    Apr 6, 2008
    Codes were checked, no scan done. Fuel pressure was checked last time and it was good. Fuel filter was checked to see if it was flowing gas and it was good. Will replace coolant sensor again tonight.
  5. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    a few things to check;
    1Inspect Battery Damaged or faulty battery and/or connections.
    [​IMG]2Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit.
    [​IMG]3Inspect Fuel Filter Clogged or dirty fuel filter
    [​IMG]4Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit.
    [​IMG]5Inspect Fuel Pump Improperly functioning fuel pump or circuits.
    [​IMG]6Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
    [​IMG]7Inspect Control Module-Ignition Faulty ignition control module or circuit.
    [​IMG]8Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit.
    [​IMG]9Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit.
    [​IMG]10Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit.
    [​IMG]11Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source.
    [​IMG]12Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source.
    [​IMG]13Inspect Battery Cable Corroded, broken or poorly connected battery cable.
  6. 03chevy
    Dec 28, 2006
    1,244
    50
    jax,fl
    14Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor.
    [​IMG]15Inspect Distributor Cap Loose or cracked distributor cap
    [​IMG]16Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor.
    [​IMG]17Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system.
    [​IMG]18Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
    [​IMG]19Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit.
    [​IMG]20Inspect Spark Plug Fouled, damaged or broken spark plug(s).
    [​IMG]21Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s).
    [​IMG]22Inspect Timing Belt Slipped or broken timing belt.
    [​IMG]23Inspect Timing Set Slipped timing chain or worn timing gear(s).
    [​IMG]24Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank.
    [​IMG]25Inspect Ignition Timing Incorrectly adjusted engine timing.
  7. cheaptric
    cheaptric Member
    Apr 6, 2008
    After a scan was completed. The distributor cap and rotor were replaced. Appears to have taken care of the problem. Truck is running better too. Will also replace the ignition coil. Thanks for the all the help.
  8. leolkfrm
    12,657
    7,766
    Another reason why scanners are the best tool in the box! thanks for posting back
