2002 f250 super duty
Discussion in 'Ford Truck Forum' started by Biglou1228, Nov 30, 2017.
  1. Biglou1228
    Biglou1228 New Member
    Nov 30, 2017
    Hi i need help on this please i have a 2002 f250 super duty v8 i took it to the dealer and the brake switch but now the truck turns on and i push the brakes to shift and it cuts off i unplug the brake switch and push the brakes and it stays running but when i plug it back it dies i order a new one and still doin the same can someone please help me out
    6,881
    4,393
    Could be a wire shorting ground on a ignition circut causing it die when the brake pedal is pressed. Look around the brake pedal make sure no wires are rubbed bare or touching metal.
    Biglou1228 and gmctrucks like this.
  3. gmctrucks
    9,057
    4,796
    I would google what you wrote down many of things can come up google is my friend.
  4. Biglou1228
    Nov 30, 2017
    I tryed to but it gives me when u driving and my problem is when i turn it on and push the brake to put it in gear it cuts off
  5. Biglou1228
    Nov 30, 2017
    Ok ill look into it
  6. gmctrucks
    9,057
    4,796
