2003 2500HD air conditioner problems
Discussion in 'Chevy Truck Forum' started by obananna, Jul 23, 2008.
  1. obananna
    obananna Senior Member
    Dec 23, 2007
    79
    Factory
    Michigan
    I have a 2003 2500HD my question is the air conditioner will blow cold air for a little bit then start to blow hot air for a little bit then back to cold. I had the freon checked it was good. Any suggestions as to what to do.
    12,609
    7,667
    check the temp damper. What control system do you have? duel or single?
  3. Johnboy
    Johnboy Full Member
    Jul 21, 2008
    19
    Tennessee
    Does it start to blow cold again when you mash the gas down, kicking the compressor back in?
  4. obananna
    Dec 23, 2007
    79
    Factory
    Michigan
    It has dual controls. Mashing the gas doesn't make it blow cold again ( it actually starts to blow cold again when the windows get rolled down).
  5. gmctrucks
    8,584
    4,175
    OK my brother is having the same thing on his HD what he did since he does a lot of driving in the ranch the radiator and condenser had a lot of weeds & trash in it he took his pressure washer and it did help it but we think it's something else because it's electronic might be a part is faulty.
  6. leolkfrm
    12,609
    7,667
    Do both sides go warm then, or just one side?
  7. obananna
    Dec 23, 2007
    79
    Factory
    Michigan
    Yeah both sides go warm.
  8. leolkfrm
    12,609
    7,667
    does it happen when the recyle button is pushed or just the air button?
  9. obananna
    Dec 23, 2007
    79
    Factory
    Michigan
    It's both when its just the ac and when the recycle is on too.
  10. leolkfrm
    12,609
    7,667
    When it blows warm can you tell/ or stop to see if the compressor is still running..Might be a problem in the compressor clutch or power feed
