2004 Ford Ranger Battery Light on
Discussion in 'Ford Truck Forum' started by ADK, Jul 16, 2009.
  1. ADK
    ADK New Member
    Jul 16, 2009
    I have a 2004 Ford Ranger 4.0L that the battery light started flickering and then came on all the time. Replaced the battery with no chage. Had the alternator tested at Auto Zone, two tests passed as good. Checking for loose connections now, serpentine belt is tight and looks good. Any ideas?
  2. crabtruck
    Welcome to the forum ADK.
    That's not southern for IDK I hope.
    Have you checked the batt voltage when the truck is off,
    and what it is when truck is running ?
    Could be good compoments but not connected well,
    loose or damaged connections. That "charge" light
    is really a voltage light, so numbers would be helpful.
  3. chickenbone
    chickenbone Senior Member
    Mar 20, 2009
    68
    Sometimes those ranger's, you have to reset the computer after a bad code from battery. Also if you changed the battery, do yourself a favor. Put new cable ends on. Best if you can crimp them on. The negative on those Trucks has to be 100%
    Ford puts cheap ends on to last about 4 -5 years. They get nasty on the inside of cable ends and you can't see it.
  4. tjzz4
    tjzz4 Senior Member
    Oct 5, 2007
    459
    29
    Sounds like an alternator going south... pretty common.
  5. songkrai
    songkrai Member
    Jul 21, 2009
    11
    Agreed. Could be alternator. Could be battery terminal cables.
