2005 f350 uploader dash switches
Discussion in 'Ford Truck Forum' started by honda cat, Jul 4, 2007.
  1. honda cat
    honda cat New Member
    Jul 2, 2007
    marine technition/ boat shop wner
    south side of chicago
    I have looked in the owners manual but i cant seem to find where i would hook accessories to these switches
    any one know where you pick up these leads or should i hook the load up rite to the back of the switch
  2. 75K30
    Those are "upfitter switches" and are already hot. you will find the other ends of the harnesses in fuse box and will have to remove the access cover to get to them. These wires will have an empty end covered with a small piece of heat shrink. The switches are only hot when the ignition is on.
    They are as follows:
    Aux circuit #1 = 1936 org/lt grn 30 amp
    Aux curcuit#2= 1933 org 30 amp
    Aux circuit #3= 1934 org/yel 10 amp
    Aux circuit#4= 1935 org.ly blue 10 amp
    Good luck.
  3. peterbilt
    peterbilt Senior Member
    May 29, 2007
    1,966
    highschool inmate, lol, work with my dad
    Florida
    and they are petty kool imo, so you can have a plow, and some other stuff.
  4. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    The harness to tie into is behind the fuse panel. It should have a little plastic catch on one end that you can release. The panel will tilt and the harness for the upfitter switches is behind there.
  5. honda cat
    Jul 2, 2007
    look and looked
    cant find the wires
    first question
    are they under or arround the fuse pannel in the truck or under the hood ?
    can any one send me a picture?
    here is my email
    calumetmarinesport@hotmail.com
    thanks in advance
  6. peterbilt
    May 29, 2007
    1,966
    Florida
    does this pic help?
  7. crabtruck
    I have never seen that panel before - what is all that ?
  8. mrjohnwayne
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    Crab that is the integrated brake controller and the upfitter switches the OP is referring to.
  9. 75K30
    here you go man. Sorry to have left you this long. I thought you were good to go.
    This is a step by step procedure.
    http://showland.org/f350/
    This includes a complete PDF file for the wiring and pictures to help you locate your wires.
    Do not forget that you also have 4 pass through wires located on the driverside just above the master cylinder. These are factory wires provided for your use, so you do not have to fish your own.
    Good luck.
  10. crabtruck
    So I snoopped the other site and I will admit they did a nice job of matching the decor of the truck.
    Don't like it. How long will it take to remove the "aux" labels and redo with some useful name after an install ?
    I also like switches i can easily reach from outside the truck without having to climb in.
    I don't know how common that type of grip is becoming for the brake,
    but I do know I have been in many situations where being able to
    maintain contact with that would have been a nightmare
    Is upfitter the new politically correct term, like sanitation engineer ?
