2006 Chevy 1500 lost 1st gear
Discussion in 'Chevy Truck Forum' started by Alan Duke, Dec 25, 2017.
  1. Alan Duke
    Alan Duke Full Member
    Nov 22, 2008
    82
    Houston, TX
    Ok..... Christmas day and I loose 1st gear (Automatic ). I know I will need a rebuild soon, but anyone have a short term remedy?
  2. greencamaro1981
    greencamaro1981 Full Member
    Feb 5, 2011
    475
    111
    detention officer
    bozeman mt
    lucas trans fix would be the best bet for you, get it warm before you add it in the stuff pours like honey make sure to drain 24 oz out before adding it in.
    JTWard and MikeG like this.
  3. JTWard
    JTWard Full Member
    Sep 3, 2012
    1,257
    946
    I'm retired.
    I going with GreenGamaro, a filter and fluid change.
  4. scavanger
    scavanger Full Member
    May 15, 2007
    1,763
    1,325
    do both, Lucas makes good stuff, the Power steering stuff works wonders .
  5. dirtrider73068
    6,881
    4,393
    If it hard part failure lucas won't do anything, unless your lucky and its a stuck valve, it could also be a bad 1-2 shift solenoid if thats the case lucas won't help will need to replace it if thats the only thing wrong with it.
    And if you already know the tranny is on the way out the door then more than likely you lost 1st for good if the tranny is already crappin.g the bed. You may as well just get ready put it in a shop and have it rebuilt. I have dealt with alot of issues on the 4l60e and if its about to go, or has internal problems its going to fail no way around it, and no short term fix either.
  6. Alan Duke
    Nov 22, 2008
    82
    Houston, TX
    1st gear comes back after it' been parked awhile. Funds are tight right now...... Will give the suggestions a try. Hope no hard parts are damaged. Thanks for the replies!
  7. scavanger
    May 15, 2007
    1,763
    1,325
    sounds like you may have a low gear seal damaged , loses pressure when oil get thinner
