2008 f250 superduty speedometer
Discussion in 'Ford Truck Forum' started by Robbie, Sep 12, 2017.
  1. Robbie
    Robbie New Member
    Sep 12, 2017
    My speedometer quit working. I changed the has in the differential. Still no Speedo. Only light displayed is engine light. Only code read is rear vss-a. Any thoughts
  2. jkeaton
    3,115
    5,197
    Yes. Probably you are on the right track.
  3. Robbie
    Robbie New Member
    Sep 12, 2017
    New vss did not change anything. Sometimes my mileage and mpg shows on display and sometimes it dont. Just in and out with a green wrench cycling through display. Amber engine light stays on.
  4. kbrown11
    kbrown11 Full Member
    Dec 5, 2015
    1,223
    2,144
    Alburquerque
    Is your ABS light on? On some trucks the VSS signal goes through the ABS module. If the ABS module goes bad, no speedo. There is also a VSS on the transmission.
    I would first check the wiring at the rear VSS, make sure the plug is clean, then check for a blown fuse.
