4L60-E/4L65-E Transmission Diagram
Discussion in 'Chevy Truck Forum' started by hotrodpc, Nov 17, 2009.
  1. hotrodpc
    hotrodpc Senior Member
    Jul 29, 2008
    7,277
    110
    Moore, OK
    Here is a poster pic of a 4L60-E/4L65-E and then broke down pics of each section of the transmission.
  2. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    And the Valve Body Assembly.
  3. mudseeker
    8,754
    580
    that's gonna bring back nightmares tonite.:eek:
  4. bradrhale
    awesome find hotrodpc. only thing missing in the parts list that goes with the pics. the numbers mean nothing to someone that doesnt know. such as myself.
  5. Crmzendrgone
    Crmzendrgone Senior Member
    Apr 6, 2009
    3,218
    Mechanic. Mr. MOM
    Arizona
    Awesome pics!!! I want to know for everyone else what makes the E different from just the 4L60? Is it in the valve body?
    Now a guestion for me what is the 4L65? Is that the replacement for the 4L60?
  6. mudseeker
    8,754
    580
    4l60 is basically the 700r4
  7. bradrhale
    4l60e is electronically controlled. the 4l65e is different from the 4l60e mostly noticeable by the 5 at the end.:rofl: the 65 is slightly upgraded from the 60. bit heavier input shaft and couple of other things.
  8. hotrodpc
    Jul 29, 2008
    7,277
    110
    Moore, OK
    and the 65 usually has the removable bell housing too. 700r4 and 4L60 are the same expained by mud. That is just where the model transitioned just like a Turbo 400 is now aka 3L80. The E as brad says is electronically controlled, so it does not have a cable or modulator to control shift points. It used sensors from the ecm and then has solenoids A&B in the trans that tells it when to shift, and lock up converter etc. Very similar, but every differant too. Many hard parts of the 4L60-E will fit 4L60 and 700r4 and many are actually recommended as to upgrade the 700r4/4L60 to be stronger.
  9. Crmzendrgone
    Apr 6, 2009
    3,218
    Mechanic. Mr. MOM
    Arizona
    knew that one:)
    So your saying by the time they started producing the 60e the hard parts were actually beefer than the predececor 700r4? So more than just the introduction of electronic control was also the more durable parts. No other design changes?
  10. crabtruck
    #10 crabtruck, Nov 19, 2009
    OK brad, here's some pix with parts lists for the 4L60-E
    Thought I had posted some of this a while back.
    Plus the cooler line list in case anyone plays trivial pursuit on trannys.
    Ports for
    200-4R, 3L30 (180), 3L80(400), 4L30-E, 4L60 (700-R4),
    4L60-E, 4L80-e, 3T40, 4T40-E, 4T60 (440-T4/F7), 4T60-E,
    4T65-E, 4T80-E, Allison (M74), Aisin (AF33-5), Aisin (AF17),
    MU4, MU5. 5L50E, 6L50, 6L80, 6L90, 6T40, 6T45, 6T70, 6T75
    hotrodpc and (deleted member) like this.
