7.3L hard start when cold
Discussion in 'Ford Truck Forum' started by wmiller, May 8, 2007.
  1. wmiller
    wmiller Member
    Aug 7, 2006
    My 97' F-250 doesn't like to start when it get below about 35 degrees. I've replaced the glow plugs and the relay so i think that system is working. When it is cold it take several cranks of the engine for it to even start smoking. I'm wondering if it could be weak injectors or a weak oil pump. the truck has 225,000 miles and to my knowledge has had no work done to the motor. Any ideas or help will be greatly appreciated
  2. mrjohnwayne
    mrjohnwayne Full Member
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    You can have the injectrs buzz tested, or have injector pressure tested, but either way gonna have to take it to a diesel shop.
  3. 03chevy
    03chevy Senior Member
    Dec 28, 2006
    1,244
    50
    factory warehouseman
    jax,fl
    you might want to wait and think like a truck driver. diesel fuel is thicker than gas. if you have a tank warmer then the fuel would be thiner in the cold weather and easier to start. the colder it is the thicker your fuel will be and harder to start unless you have a tank warmer to keep the fuel warm. hope that helps out
  4. peterbilt
    peterbilt Senior Member
    May 29, 2007
    1,966
    highschool inmate, lol, work with my dad
    Florida
    my dad has the 6.o powerstroke in his and in the winter time when i used to live in ohio, he plugged it in. there should be a plug in the front under the grille or in it, but if there isnt, get an electrical dip stick so you can heat the engine oil. does this help any?
  5. PickUpGirl787
    PickUpGirl787 Senior Member
    Dec 28, 2006
    711
    Cut Lawns :), and Landscaping, work at Panera Brea
    Illinois
    not all trucks have the plug especially if you bought it where it doesnt get that cold and then brought it to a place taht does get cold
  6. mrjohnwayne
    Apr 15, 2005
    4,062
    101
    Oil and Gas field
    Pick up girl is right. not all came with the plug. Almost all came with the block heater but not plug.
  7. peterbilt
    May 29, 2007
    1,966
    Florida
    but anyone can get an electric dipstick. pick one up at auto zone for 20 bucks.
  8. 72'CaminoKid
    72'CaminoKid Senior Member
    Jun 19, 2005
    2,757
    29
    that only helps with the oil not the gas. sorry about your dads 6.0
  9. 75K30
    is the oil level for the HPOP full? Sometimes the checkvalve leaks, and allows the level to go low, and it has to fill again while the truck is cranking over. It would indicate a cold start problem, when in reality it is a level problem, and easily fixed with a new check valve.
    Some of the 7.3's also had a CPS troubles. I believe that tach should rise to about 100 rpm while cranking.
    Although I doubt the CPS is the trouble, I do believe the reservoir level could be giving you trouble.
  10. 72'CaminoKid
    Jun 19, 2005
    2,757
    29
    alot of the 7.3's have the cps problem but generally it is indicated by the truck will start one time but not the next and if you do get it started it will cut off while driving
