84 chevy dual tank circuit
Discussion in 'Chevy Truck Forum' started by knlwarfield, Jun 24, 2008.
  1. knlwarfield
    knlwarfield New Member
    Jun 24, 2008
    Does any one know were i might find troubleshooting and wiring diagrams for my 1984 dual tank circuit. i can not get it to pull fuel from the right tank anf the fuel gauge will peg over full on the right side. any help would be greatly appreciated
  2. Chevy_Finatic79
    Chevy_Finatic79 Senior Member
    Mar 30, 2008
    494
    38
    Self Employed Mechanic
    Lincoln NE
    maybe you have rotted lines or a bad selector switch
    12,324
    7,420
    have someone work the switch and feel to see if the valve is working, your guage works so the in cab part sounds ok
  4. stumpuller454
    Dec 26, 2007
    2,206
    65
    if it reads way over full you`ve probly got an open wire, and those selectors are common, i had to change a couple in my 80` and i only had it 3 years!!
    300TH POST WHOOHOO!!
  5. DeepDan
    DeepDan Full Member
    Apr 27, 2008
    24
    Agriculture Extension Agent-Livestock
    Angier, NC
    Isn't there a solenoid in under the bed that can go bad? My 87 does exactly what his does, the gauge registers, but she aint pulling fuel from the right tank. Course, I suppose the difference would be his fuel pump's on the motor and mine's in the tank, right?
  6. knlwarfield
    Jun 24, 2008
    Thinking the selector is bad. ohmed the floats got good readings at different float positions. took selctor off a junk truck i have and the gauges read properly. I,ll go buy one see what happens. Thanks for the help eveyone. it is greatly appericiated.
