86 chevy 350 not getting fuel
Discussion in 'Chevy Truck Forum' started by hllywd322, Sep 16, 2012.
  1. hllywd322
    hllywd322 New Member
    Sep 16, 2012
    I replaced the fuel pump, filter and fuel line, i pour gas in to carburetor and it turns over and runs briefly, however as soon as the gas in the carburetor is gone it shuts off and won't run the fuel filter doesn't have so much as a drop of gas in it...any ideas as to why? have already tried both fuel tanks.
  2. Down South
    Down South Senior Member
    Jan 25, 2012
    462
    21
    South MS
    sock/fuel pick up in the tank or the rubber lines connecting the metal line.
    Is there a fuel filter under the cab?
    DS
  3. dirtrider73068
    6,444
    3,854
    If he has a carb it will be on the carb don't think they put filters on the frame but may have in that year, are you sure pump is pumping, is it the pump in the motor or one in the fuel tank.?
    Why did you replace pump? for the symptom your having?
    Try this take filter loose turn engine see if fuel comes out.
  5. dirtrider73068
    6,444
    3,854
    Oh just thought of this the carb filters go in one way they have a flap valve keeps fuel at the carb to start easier is it in the right way, iirc the flap valve goes in first against the carb.
  6. Down South
    Jan 25, 2012
    462
    21
    South MS
    #6 Down South, Sep 16, 2012
    It is dual tanks? Same on each tank? The selector switch may be a issue. Its common.
    DS
  7. gpmorgan
    gpmorgan Auto Banned
    Nov 21, 2009
    2,687
    288
    83
    forklifts and equip tech
    Tupelo Ms.
    bypass the selector switch and try just one tank.
    I betcha this will be the bingo/right?
  9. leolkfrm
    12,433
    7,514
    you are describing an old the block pump carb set up, is this what ou have? if so look for bad spot in the fuel line farther back it may be sucking air
