88 chevy tail light problem
Discussion in 'Chevy Truck Forum' started by mechman, Jan 13, 2011.
  1. mechman
    mechman New Member
    Jan 13, 2011
    Help! I have an 88 chevy truck, "sometimes" the left tail light goes out when I hit the brake and the brake light won't come on... I thought it was a ground, or shorted wire. Replaced the rear wiring harness to both rear lights (plugs in to a 4 pin connector LH rear frame), also replaced the LH light assembly, still the same problem.. what am I missing?
  2. Oldmech
    Oldmech Full Member
    Jan 12, 2010
    1,763
    214
    Iowa
    you replaced the light assembly? Including the plastic board on the back of the light itself? have seen several of those die... if it isnt the board the wiring and lights plug into then its got to be a wiring problem somewhere along the line.. I assume the turn signal for the left side is also not working?
  3. 1976jayman
    1976jayman Full Member
    Jan 2, 2011
    hi mechman, does the truck have aftermarket trailer hitch wiring?, sometimes if somebody spliced the wiring for the trailer hitch wiring the connection might be loose or corroded in the harness.
