89 chevy 2500 wont go into overdrive
Discussion in 'Chevy Truck Forum' started by justinc87, May 16, 2010.
  1. justinc87
    justinc87 Member
    May 12, 2010
    I bought a 89 silverado from my grandpa for $500, he said i'd have to get it running right though. My problem is that it wont go into overdrive, the truck just sits idle and will rev up as if it were still in neutral. When I put it in drive the truck will run but has a hard time shifting. A mechanic friend of mine said it's probably a sensor problem( at least for the overdrive). I'm not sure if the shifting is the same problem. Anyone have any ideas or things I can try?
  2. Boudin
    602
    I'm assuming you have the 700R4 transmission, right?
  3. Boudin
    602
    Sorry, I just noticed you said it was a 3/4 ton. I don't think the 700R4 would be in anything but a 1/2 ton.
    Do you know what transmission it has in it?
  4. justinc87
    justinc87 Member
    May 12, 2010
    I would think so, sad to say this is my first older chevy truck so i'm still familiarizing myself with them. It's whatever came stock with it haha.
  5. wyochimneysweep
    wyochimneysweep Senior Member
    Mar 26, 2010
    315
    Diesel Tech
    Fargo ND
    gas or diesel?
  6. wyochimneysweep
    Mar 26, 2010
    315
    Diesel Tech
    Fargo ND
    does reverse work
  7. justinc87
    justinc87 Member
    May 12, 2010
    It's gas, it's got the 350 in it. It does go in reverse. All gears work fine except the drives, overdrive does nothing and drive struggles to shift.
  8. Hwy64
    Hwy64 Full Member
    May 18, 2010
    14
    89 chevy 2500
    Well, the '89 Chev. and GMC 3/4 vans definitely did have 700R4s in them. Got two. Also have an '89 Chev 1 ton van that has a T400 in it with the 350 TBI.
  9. oldford
    oldford Full Member
    Nov 7, 2009
    Eastern Maine
    I've got an 89 k2500 with a rebuilt 700r4 in it that had the same symptoms. It's time for a trip to the transmission shop.
    GL, eric
  10. wyochimneysweep
    Mar 26, 2010
    315
    Diesel Tech
    Fargo ND
    sticking throttle vavle? they have a junior shift kit that will fix the stickie vavle.
