91 toyota p/up crank no start
Discussion in 'Toyota Truck Forum' started by 1LowYota, Jun 6, 2010.
  1. 1LowYota
    1LowYota New Member
    Jun 6, 2010
    Need help with a 91 Toyota P/Up that will crank but no start. Any suggestions. I have tried to pop the clutch while being pulled, the engine will crank over but once I hit the gas its boogs down.
  2. mudseeker
    8,754
    580
    welcome to the forum.
    to start, we need a little more info from you.
    engine?
    history that lead up to this problem and what you have tried so far woud be a great start.
  3. 1LowYota
    1LowYota New Member
    Jun 6, 2010
    #3 1LowYota, Jun 6, 2010
    Engine is 2.4L L42BL. It is a custom truck that I do not drive a lot and has sat for a little while. I have drained the old gas out of the tank and lines. I have removed the starter and had it tested to make sure that wasnt it either. The truck used to run fine before it sat. I have jumped it before by poppin the clutch while being pulled. The engine is completely rebuilt and has around 25000 miles on it. When I turn the truck on I can hear the pump turn on.
  4. mudseeker
    8,754
    580
    sounds like you just need to clean the carb. i play with newer engines, so am no help, but others will reply sooner or later.
  5. 1LowYota
    1LowYota New Member
    Jun 6, 2010
    I dont think its an intake issue, it is just not getting any fuel. anyone else have any ideas
