92 chevy 350 no start
Discussion in 'Chevy Truck Forum' started by zazlo, Apr 19, 2008.
  1. zazlo
    zazlo Full Member
    Apr 19, 2008
    25
    mechanic
    vancouver bc
    #1 zazlo, Apr 19, 2008
    i have a 92 chevy pu that i am able to predictably reproduce a no start condition.The vehicle will start normally , then the ignition switch is turned to the off position or to the locked position.When restarting there is no spark or fuel pulse but there is power to the coil.Relesing the key and recranking allows the vehicle to start ,turning it off again ,it will start a few times then not start.This condition happens hot or cold The ignition module was replaced with no change and the dist is one year old. I also tried a map sensor with no change.Where is the pcm located as I would like to check the power and grounds.Wiggling the ignition switch when the fault occurs seems to have no effect.Im helping a friend who is out of town right now and just trying to repair this before he gets back.Thanks for any advice:confused: Just discoverd that if i continue to crank the vehicle over for aprox 8 seconds it will begin to give both spark and fuel pulse.does the ecm (computer for the fuel injection,im a dodge mechanic] go into a prelearned mode if the cmp signal is missing?
  2. gmctrucks
    8,270
    3,856
    What about the ignition switch that's on steering column. When you say will not start does it try to start or it's just dead? Mine went out and when it did it would sometimes start then it was dead to the world when you buy the new switch it comes with directions. Maybe have him drive it home and then mess with it just don't turn it off also wait a while others will chime in. Good luck! GMC
    PS-It's not the switch where you insert key into it's on the column that has a rod on it like towards the brake/gas pedel on the top part of column but the key moves the rod to start it or tell it power it up to start or turn on radio or shut off.
  3. zazlo
    zazlo Full Member
    Apr 19, 2008
    25
    mechanic
    vancouver bc
    when it does not start, it cranks fine but has got no spark or fuel pulse at the tbi injector.thanks for the reply gmc trucks
  4. 436'd skylark
    436'd skylark Senior Member
    1,143
    Mac Tool Distributor
    Pennsyltucky
    ignition module or pick up coil.
