92 GMC Sierra c1500 blowing white smoke
Discussion in 'GMC Truck Forum' started by chrismclaws, Apr 10, 2011.
  1. chrismclaws
    chrismclaws Member
    Aug 4, 2010
    When ever the truck is sitting and has cools down when I start it there is a puff of white smoke that comes out of the tail pipe. It's a 1992 Sierra c1500 GMC with 169,000 miles on it. Is this puff of smoke burning oil or to much gas? I do have to put in about a qt of oil by the time I have a oil change evey 3 months.
  2. c15004ever
    c15004ever Senior Member
    Apr 6, 2011
    84
    Ft Campbell, KY
    im no expert, but it sounds like your valve seals are no good. Common in these trucks around that many miles, my iroc-z does the same thing. Maybe someone else can explain it better
  3. turfking
    turfking New Member
    Apr 10, 2011
    My '93 has 134,000 miles with a 4.3L and it does the same thing.Valve stem seals are gone. I just watch the oil level and try not to start it in front of a crowd.
  4. gmctrucks
    8,269
    3,856
    The seals can be replaced without taking off the heads talk to some local tech.
  5. jimboflies
    jimboflies Full Member
    Mar 14, 2011
    30
    Beaumont,Texas
    In my experiance , white smoke usualy means water vapor?
  6. darisb
    darisb Senior Member
    Feb 7, 2008
    50
    Buena Park, CA
    My 92 K1500 was doing the same thing. White smoke at startup and it went away after it warmed up. My got progressively worse over sevearl months until it was blowing white smoke almost all of the time. The truck is an extra vehicle that I only drive once in a while. Keep any eye on your coolant overflow tank. The level should remain failr constant. If not, you've got a leak.
    I tried replacing the head gaskets, but it continued to blow white smoke. I pulled them a second time and took them to a local shop. The diagnosis was a cracked head. They sold me a rebuilts set for a very fair price. The owner gave me a long list of things to do when putting it back together. It's been running great ever since.
